Old 04-18-2014, 02:22 PM   #57
CSG David
CSG David's Avatar
Originally Posted by stockysnail View Post
I'm running some 18"x8 forged wheels that weight 17.8lbs if you know anyone that has used ones for a straight across to trade. They retailed for about the same amount too ($650). I got a set of 5 for $1200 (Neuspeed RS10). Basically looking for either a trade or less than $200 per wheel in 16" that weight under 15lbs. I guess I'll work on my baller status to get these wheels.
Are you trying to reduce rotational mass to drag race? The 17x8 might work better for your application to get the best of both worlds.
Old 04-18-2014, 02:28 PM   #58
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I just want a light set of wheels for summer daily driving use and a few HPDE track days and maybe one or two autocross days. I don't plan on drag racing as I prefer to keep my clutch's life, especially since I'm supercharged on a stock clutch.
stockysnail is offline   Reply With Quote
Old 04-18-2014, 04:51 PM   #59
CSG David
CSG David's Avatar
More usable grip with the 17s and the possibility to expand with a BBK is there as well. On top of that, there is a much larger selection of tires available for your application. The downside is the weight is not as formidable as 16x7...which is REALLY light.
Old 04-18-2014, 05:24 PM   #60
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by SP86 View Post
Obviously not mounted but I've been considering 16s.. Here's my extra set of Starion wheels mocked up next to the frs
Do this. I fucking love 80's wheels on this car
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
SP86 (04-18-2014)
Old 04-18-2014, 06:41 PM   #61
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
here is mine on CCW classics
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following 2 Users Say Thank You to WolfsFang For This Useful Post:
Manji (12-16-2014), SP86 (04-18-2014)
Old 04-18-2014, 07:55 PM   #62
SP86
2S Crew
SP86's Avatar
Drives: a 2013 FR-S
I may a little down the road I kept fighting myself with buying adapters though ended up ordering ccw's
Man I hope I don't regret getting 17x8s and 17x9s because I do like 16s we'll see when I get mine mounted ahah
My 2013 FR-S
SP86 is offline   Reply With Quote
Old 04-19-2014, 08:03 AM   #63
Trettiosjuan
Drives: GT86
Autec Wizard now painted silver
Trettiosjuan is offline   Reply With Quote
The Following 3 Users Say Thank You to Trettiosjuan For This Useful Post:
drewbot (01-05-2015), funwheeldrive (12-15-2014), korhun (06-19-2019)
Old 04-21-2014, 04:56 PM   #64
stockysnail
Just the tip
I doubt I will ever go BBK. Are you saying more grip because of a wider tire is possible with 17" (if I go 17x8) compared to 16x7 or 16x8? I'm considering keeping my current 18x8 17.8lbs forged, going with 17x9 like RPF1, 17x7 Kosei, or 16x7 or 16x8. I'd be running Bridgestone RE-11 in all the examples. I have ~250hp (supercharged) to the wheels and don't plan on any more in the near or maybe even no more ever. I only lose grip currently when the tires are cold (from sitting) and I floor it (when dry out). I'd expect 16x7 with 205 or 215 width running RE-11 to perform smilarly to the 18x8 225 width I'm running currently. I'm leaning towards 1 because of weight and tire cost. A few track days and autox are my only thing planned aside from daily driving.
CSG David or other CSG, could you rate them or something in order of best performance based on my above use? I'm trying to get someone to help me lean one direction or another.
Old 04-21-2014, 06:27 PM   #65
Skurj
Drives: SOLD...
Just tossing this out there.. but whats the narrowest rim that will fit and is available in 16" (thinking for winter duty next season) anything in 6" or 6.5"?
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 04-21-2014, 06:58 PM   #66
stockysnail
Just the tip
4 spare tires will fit and they are tiny.
Old 04-21-2014, 09:50 PM   #67
CSG David
CSG David's Avatar
With the Innovate kit, you will benefit with a 225 tire on a bigger track and 245 tire on a smaller track. For competitive autocross, I'm sure you'll attempt to fit some massive 275s on a 7" width tire or something just to get every ounce of grip possible. The issue is making sure you can get sufficient heat in the tire for your intended application. Even with boost, the 245 tire may not get sufficient heat for optimal grip. In this case, I would generally recommend a 245/40/17 tire, however, based on your setup, I see that a 225 is an okay tire to run. Running less, however, you're just limiting your grip potential. For best acceleration, Mickey Thompsons on 16s would be great right?
If you can, run a 17x8 +42 TWS T66-F with a 225/45/17 or a 17x9 +35 Wedsport TC105N with 245/40/17 tires. Both setups are fine and fairly dependent on application and desires. Tire selection on 17s is much greater. Everybody has preference, but I recommend RE11A for DD cars and RS3s for track setup. NT01, RC1, or RA1 are great tires if you like running with R-comps. With a grippier tire, you don't need to run as wide of a tire, however, having a fat sidewall also means slightly less response.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
53Driver (04-21-2014), sc0urge (05-27-2014), stockysnail (04-21-2014)
Old 04-23-2014, 02:15 AM   #68
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
here is mine
still don't know if i like that bigger sidewall, last year i was on 18 inch wheels... i really preffer the 16' look, but, can't say if it will give a better handling or not...
Walla Walla is offline   Reply With Quote
The Following 2 Users Say Thank You to Walla Walla For This Useful Post:
dori. (05-09-2014), GuerillaRacing (04-23-2014)
Old 04-23-2014, 01:41 PM   #69
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Looking good. I dig the large sidewall look so far on our FR-S also, as well as the old school vibes.
GuerillaRacing is offline   Reply With Quote
The Following User Says Thank You to GuerillaRacing For This Useful Post:
Walla Walla (04-23-2014)
Old 04-23-2014, 09:36 PM   #70
Red2Liter
Drives: Subaru BRZ Limited, Red
I bought 205/55 -16 Michelin Alpins for winter in the Northeast mounted on 16 X 6.5 inch Rials from Tire Rack.
The rolling circumference is less than 20mm larger than the original equipment tires which yields a negligible difference in gearing. Used the tires through two winters with great success. The slightly narrower footprint of the 16's yields slightly better tire load and traction.
There's probably some gains in traction to be made by mounting wider rubber on larger wheels. The obvious trade-off is in tire/wheel weight and rotational mass under acceleration. I'm planning on replacing the OEM tires with the stock size 17's and upgrading the rubber compound over the low rolling resistance OEM's. Probably see a small decrease in fuel economy then.
Red2Liter is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 05:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 07:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-28-2012 12:20 AM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 09:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
