#589 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
A shot in the dark here since this is old but do you know anywhere to get the motegi traklites in 16x7. Looks like on their site they start at 17"s now. Im guessing I have to go used. But pound for $$ looks like the best option and that offset is good too |
#590 |
Only users lose drugs.
Drives: All the time
The Traklite1 I mention are from their older forged line and no longer sold. The current Traklite line is cast/flow formed, and is heavier, but less expensive...still, not bad wheels. They also don't seem to be available in 16" either. I was lucky enough to scrounge up a used spare set, for the inevitable damage/replacement that happens over time. For now, I have a street set and a track set with different rubber.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#591 | |
Only happy when it rains.
Drives: series.blue
Apparently the Volk TE37 Gravel edition come in 15x7 and are supposedly 11.5 pounds still and will fit our cars. I'm going to look into that. |
#592 |
Drives: 2014 Ultramarine FR-S
| The Following 5 Users Say Thank You to NLSP For This Useful Post: | FLIPDADY (10-12-2018), HKz (10-12-2018), JD001 (10-12-2018), Kenny_LongWrench (10-12-2018), new2subaru (10-12-2018) |
#593 |
#594 |
I've seen them advertised in the 16.5lbs range. But if I remember correctly when I weighed them on my bathroom scale, it was more like 17.5lbs. Can't say how accurate my scale is though; it's an analog piece from Ikea lol.
#595 |
Drives: 2014 GT86
Advertised might be lightest of that size. But seen often that different PCD/offset/concavity change weight a lot.
#596 |
Moutain Runner
Any known 16s or 15s that fit the PP brakes? I recall the WRX/STi having some options.
#597 |
Tacticool_BRZ
Drives: ZC6 - AW11
#598 |
Moutain Runner
#599 |
I don't think any 16s fit over the PP's brakes. Not basing that on firsthand experience, but rather everything I've read saying 17s are the smallest you can get away with the factory Brembos. Can you get 16" steels for the PP cars? (winter wheels) I don't think you can..
#600 | |
Moutain Runner
Or maybe it was the FHI 4pots. |
#601 | |
I'd believe the FHI calipers before the Brembos. I just don't think there's enough room in a 16" barrel to accomodate the Brembos, but again, I could be wrong. Just a WAG. Edit:, so I took a look at my 16s and the clearance between the barrel and the standard US front caliper..there's a hair over a 1/2" clearance, just eyeballing it. Not a lot of room to stuff a bigger rotor and caliper in there and still keep adequate clearance. Just the difference between a 300mm versus a 320mm rotor eats up nearly all that room, nevrmind a bigger caliper too.
#602 | |
Seen here with the dual drilled option on an STI: ![]() Plent of 16 inch wheels to fit over FHI 4 pots. - Andrew |
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 05:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 07:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-28-2012 12:20 AM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 09:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 12:17 PM |
