86WORX
Old 12-11-2015, 12:36 PM   #435
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by MrDinkleman View Post
I thought I was alone or among just a few. I intend to go to 16" wheels after I get my FRS/BRZ. Just not sure of width and offset. Probably a 225/50 tire, though.
Will a 16X8, 42mm offset fit without rubbing?
Finding a good 16" wheel is less of a problem than it is to find a decent selection of 16" rubber. 225/50 seems to be the best size to go, in order to get a decent selection. If you want to go wider, you'll probably be better off sticking with 17's, unfortunately. Fewer tires to choose from, and anything wider than a 225/50 really needs something wider than a 7" rim. There are a few wheels to choose from in 16x8, but either the offsets are too aggressive, or they are far heavier than they could/should be.
venturaII is offline   Reply With Quote
The Following 2 Users Say Thank You to venturaII For This Useful Post:
MrDinkleman (12-11-2015), Trettiosjuan (12-11-2015)
Old 12-11-2015, 01:38 PM   #436
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have a 205/55/16 tire on a 7" rim. Better to be a bit stretched ..
Old 12-11-2015, 04:03 PM   #437
MrDinkleman
Drives: 2016 Oceanic, "base" model
I appreciate your input, but I will have to respectfully disagree with this. As you say, 225/50 is the best size to go with, which is my plan. All the tire manufacturers produce that size so finding a tire is not a problem. However, so far, I can only find 7 high quality 16" rims that aren't ridiculously heavy:
1. Enkei Sport ES Tarmac 16X7 et 45mm (might be discontinued)
2. Enkei Sport ES Tarmac 16X8 et 45mm (also might be discontinued)
3. Work CR01 16X7.5 et 39mm
4. Work Seeker DX 16X7.5 custom et up to 50mm
5. Work Seeker FX 16X7.5 custom et up to 50mm
6. Work Seeker CX 16X7.5 custom et up to 50mm
7. Volk CE28N 16X7 et42mm
Ronal has the aero-styled (which I like) R50 but the 16X7.5 weighs 21lbs!
Centerline used to have a tuner line of 16" wheels but I can't find them on their website anymore...
I would love to get and refurbish used BBS RS 3-piece wheels but I don't think they made them with 5X100 bolt circles.
Ironically, the Volk is the lightest, most expensive, and probably the best quality but it also has the lowest load capacity rating of 520kg. The Enkeis are the cheapest and have the highest rating of 690kg but I read contradictory reports that the ES Tarmac line is discontinued and they are only selling current stock. Finally, the Work wheels are of mid-range price-wise and supposedly pretty good quality but I haven't been able to find out their weight and load ratings. The CR01 is a welded three-piece wheel so I will give it some leeway for extra porkiness just because I like 3-piece wheels.
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
NissanGuy (12-28-2015)
Old 12-11-2015, 05:12 PM   #438
churchx
churchx's Avatar
Drives: 2014 GT86
If you consider Volk CE28N, why not TWS T66-F? (10.63lbs for 16x7 +48)
The Following User Says Thank You to churchx For This Useful Post:
Old 12-11-2015, 05:35 PM   #439
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
I got 16 inch with winter tires, it looks ugly :S
Jfheisenberg is offline   Reply With Quote
Old 12-11-2015, 06:18 PM   #440
MrDinkleman
Thanks. I guess there are 8 possibilities
But...
1. My fault for not mentioning, I was looking for an et closer to 40 because 225/50 will bulge out more than the stock 215/45-17 plus it's more flush.
2. I am not a big fan of the 5 pairs of spokes (vs. CE28N's 10 independent spokes) style
Old 12-11-2015, 06:21 PM   #441
venturaII
venturaII's Avatar
Actually I think we're on the same page... I was referring to the lack of variety of sizes available in a 16" in a decent performance category. 225/50 seems to have the largest selection. I'd like to have a 245/45-16 on a 16x8 or 9, but there's no tires of interest in that size and no wheels that are worth spending the money on; they're either aggressive +25 offsets or more, or too heavy to make it worthwhile, or too expensive for my wallet.
You can add the Motegi Traklites I'm running to your list, since it doesn't seem like you're looking for a particular style. 16x7 +40 and 12.5 pound for under $300/ea. I'm not a huge fan of the 5 spoke look, but they were ever so slightly used and a package deal with the tires and a screaming bargain as a result, so I pulled the trigger. I'm all about bang for my buck.
The Following User Says Thank You to venturaII For This Useful Post:
Old 12-11-2015, 06:31 PM   #442
MrDinkleman
Huh! Cheap, light, and strong.
When did Motegi go upscale?? They always seem to just be the cheap wheels you buy at Pep Boys. Whowuddathot?
Thanks!
Old 12-11-2015, 06:43 PM   #443
venturaII
venturaII's Avatar
Thanks!
Yeah, they're forged, reasonably priced, and have a load rating close to OEM. It's stamped right on the side, so I'll post it up when I head out to my car...
EDIT: Well, I thought it was stamped on the outside part of the wheel, but it's not. I remember seeing it somewhere though...I'm swapping out for my winter setup this weekend, so I'll take a closer look.
Old 12-11-2015, 07:10 PM   #444
kuno
I found enkei RPO1 16x8 +38. Look pretty good and most importantly cheap..
kuno is offline   Reply With Quote
Old 12-12-2015, 02:15 AM   #445
MrDinkleman
Are these discontinued? I don't see them on Enkei's website...
Old 12-12-2015, 03:10 AM   #446
churchx
churchx's Avatar
Drives: 2014 GT86
MrDinkleman: it (TWS) was mentioned more as lightest 16" that being made/sold now, not discontinued, and strong enough (IIRC forgery by Taneisha). I'm not sold by it's looks too, but functionality wise they seem to be THE wheels to have, except maybe too expensive for some.
Old 12-12-2015, 03:23 AM   #447
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
If you really are shopping for 16's, I do have my 16x7 Slipstreams with the 225/45 Dunlops available.
Kostamojen is offline   Reply With Quote
Old 12-12-2015, 03:39 AM   #448
kuno
I think so. Maybe before the rpf1 era. I could be wrong though
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 05:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 07:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-28-2012 12:20 AM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 09:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
