86WORX
Old 04-18-2015, 03:34 AM   #379
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Bridgestone RE-11 in 245/45R16 is my vote for tires. I use it for track, autox, daily, and it's even good in rain. Since they are in the top category of summer tires they don't work very well below 45 degrees (no summer tire does), but that's what my winter tires are for.
stockysnail is offline   Reply With Quote
Old 04-18-2015, 02:14 PM   #380
yo joshman
yo joshman's Avatar
Drives: ae86/frs
Originally Posted by GuerillaRacing View Post
Track day
what are your initial impressions on the wheel n tire setup on the corners?
yo joshman is offline   Reply With Quote
Old 04-18-2015, 03:33 PM   #381
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
It would have been better with a proper alignment, but the tires seemed to lose traction with all driver aids off and full throttle turning. I've only tracked on this setup so it's hard to compare to a 17" or 18" setup. The other 86s present had similar mods (suspension, wheels & tires) and were putting down similar lap times, though the 16" setup on this car took the fastest lap of the day
GuerillaRacing is offline   Reply With Quote
The Following User Says Thank You to GuerillaRacing For This Useful Post:
yo joshman (04-20-2015)
Old 07-04-2015, 05:12 PM   #382
stevesnj
stevesnj's Avatar
So I am looking into 16's I used this calculator and debating 245 and 235. How close is too close until there's interference with any suspension items? 245 are ideal which brings the gear ration back to 4.10 so this is prefered. I forget who made this calculator but I think the end of the red line may be where suspension parts are. I used the Y axis line as a guide to clearance if it is the max. Anyway the offset for the fender lip should be okay. I dont want the tires sticking past the fenders. I also am going to put TRD lowering springs.
thanks for any help
steve
My 2016 Build thread
Old 07-05-2015, 02:42 AM   #383
stockysnail
Just the tip
thanks for any help
steve
I can't remember, nor do I have 16s but I think you'll need to run +25 offset to get them to fit. Get a store to order then for you (if they allow returns in they don't fit) so you can try them on for size.
The Following User Says Thank You to stockysnail For This Useful Post:
stevesnj (07-05-2015)
Old 07-05-2015, 03:09 AM   #384
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
The problem will be the limited number of 235/245 sized tires to choose from.
Kostamojen is offline   Reply With Quote
The Following User Says Thank You to Kostamojen For This Useful Post:
Old 07-05-2015, 09:48 PM   #385
bakerr6
Drives: 2013 raven black fr-s
I'm running 16in wheels with 225s all around. The car seems fairly stable but I do get some sidewall deflection if I'm more than half throttle on any hard coners
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
NWFRS (07-13-2015)
Old 07-05-2015, 10:29 PM   #386
stevesnj
stevesnj's Avatar
Originally Posted by bakerr6 View Post
I'm running 16in wheels with 225s all around. The car seems fairly stable but I do get some sidewall deflection if I'm more than half throttle on any hard corners
What brand tires you have and whats the offset front and rear? Thanks!
Old 07-13-2015, 12:57 AM   #387
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Originally Posted by Manji View Post
Am fitting these bad boys in the next few days.
Surprised how light they are.
More pics here: https://www.facebook.com/86steeze
Got any pics of the CR01 on the car? I'm very interested in how they look, and what size & offset.
blue cat is offline   Reply With Quote
Old 07-17-2015, 10:20 AM   #388
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
What is your rim width?
Old 07-17-2015, 10:54 AM   #389
bakerr6
Sorry guys I'll pull the specs tonight. I believe the width is 7in
stevesnj (07-17-2015)
Old 07-17-2015, 12:31 PM   #390
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is better to use 215 or less in 7''.
Old 07-17-2015, 12:53 PM   #391
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
225 is certainly acceptable for use on a 7" rim, especially in taller aspect ratios required for running smaller diameter wheels. I run 225/50-16s on 16x7s and have zero issues at all. The tire does not roll over like everyone thinks it will, even when autocrossing, and I'm only running pressure in the high 30's.
venturaII is offline   Reply With Quote
Old 07-17-2015, 12:56 PM   #392
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I have some 15" Enkei RCG4's that'll be my winter wheels!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 05:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 07:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-28-2012 12:20 AM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 09:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
