Old 12-12-2014, 12:05 AM   #169
dvdmzjr
Drives: Scion FR-S
Originally Posted by theburz View Post
For those of you that have gone for a 16in wheel but a meatier tire (say a 50 as opposed to the usual 45), what differences (if any) do you notice in how the car behaves?
I track my car a bit and I'd like to know how that setup would be on the street as well as the track.
I don't know that Blizzaks are a good comparison to regular tires. Mine are 205/55R. It feels a little more stable/planted into the corners, but a little more loose out of them (compared to stock). I kind of want to try out a summer tire in that size, just to find out what the characteristics would be.
dvdmzjr is offline   Reply With Quote
Old 12-12-2014, 12:20 AM   #170
Bergen23
Drives: '15 Halo FR-S
Just ordered a set of 16x8 +25 Enkei Compe's. @GuerillaRacing car was enough motivation for me to do that, very looking forward to summer time
Bergen23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bergen23 For This Useful Post:
GuerillaRacing (12-12-2014), mkiisupra (12-15-2014)
Old 12-12-2014, 03:47 AM   #171
Trettiosjuan
Drives: GT86
Basically you have more tire suspension, both vertically and laterally. More rolling comfort and more forgiving taking bumps in corners. More forgiving, progressive if you will, in communicating grip loss. More movement laterally also but in my opinion that helps feeling weight transfer easier. Less rotating inertia keeps the wheels down better and helps acceleration/braking. In theory the shoulder can roll over sooner but if you use the right tire for the purpose it's not a problem, the car isn't that heavy. AE86 and MX-5 have tracked successfully on 14"-15" for decades, and with the larger tire circumference for the ft86 platform, 16" is right up there. Plenty use 16" for tracking in Japan. This is NA, if you run FI then perhaps you need to run bigger because you need bigger brakes. Comments above are also disregarding tire width, easier to run wide on 17"+ but that can often be debated how necessary or functional that is esp. on NA cars. Much depends on track and ambient temperatures.
Trettiosjuan is offline   Reply With Quote
Old 12-12-2014, 06:55 AM   #172
troek
troek's Avatar
Drives: 2012 Toyota 86
i run 205/55r16 rs3 on a 16x7 and it is a great combination. i wanted try a 205/50 but, i was dead set on the rs-3 and they dont make that size. on the 100r at fuji i can hold a steady 1.1 g, there is plenty of grip in this tire size.
The Following 2 Users Say Thank You to troek For This Useful Post:
chaoskaze (12-23-2014), Trettiosjuan (12-12-2014)
Old 12-12-2014, 07:25 AM   #173
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
I think I'm going to have to get me a set of 16" wheels. I like the meatier tire look.
Amaya is offline   Reply With Quote
Old 12-12-2014, 08:21 AM   #174
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Enkei RS05 16x7J, inset 48:
The Following 4 Users Say Thank You to nikitopo For This Useful Post:
chaoskaze (12-23-2014), new2subaru (04-14-2018), Trettiosjuan (12-12-2014), xxBrun0xx (12-23-2014)
Old 12-12-2014, 08:23 AM   #175
Trettiosjuan
Drives: GT86
Good looking wheel. Weight?
Old 12-12-2014, 10:30 AM   #176
troek
troek's Avatar
yeah those look sick
Old 12-12-2014, 12:20 PM   #177
Timmy_Jones
Spun
Drives: 17' Focus RS
Crappy pic, but here is my winter setup:
Timmy_Jones is offline   Reply With Quote
Old 12-12-2014, 03:08 PM   #178
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
7.2kg
The Following User Says Thank You to nikitopo For This Useful Post:
Old 12-18-2014, 04:01 PM   #179
Lateral G
Drives: 2017 Series.Yellow + Perf Package
Do you know how much weight savings you netted at each corner?
Lateral G is offline   Reply With Quote
Old 12-18-2014, 05:13 PM   #180
srizzors25
Daedalus Moto
srizzors25's Avatar
I have 16x7.5 +50's on the car. net weight seems to be about the same as the stock wheels/tires. Overall diameter is about the same too because the snow tires on there are a higher profile.
I'm fairly happy with how it looks but I'll probably end up 18's when summer comes around
The Following User Says Thank You to srizzors25 For This Useful Post:
Lonewolf (12-30-2014)
Old 12-18-2014, 06:39 PM   #181
Trettiosjuan
Drives: GT86
What are they? Looks good to me.
On the te37 16x7 with the lightest 205/55 tyres I saved a massive 6,2kg (14lbs) a corner compared to stock. But wasn't completely happy with that tyre, with a normal weight summer tyre the weight loss was 4,5 kg (10lbs) a corner and very pleased with that setup for DD and back road fun.
Old 12-22-2014, 01:19 AM   #182
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Got confirmation from Works JP that my wheels are made and are leaving soon.
16x8.5 +16 Meister CR01.
Was disappointed when I got my current set of Meisters. I got S1R's. Everyone said 9" wide +35 sat flush, but it didn't sit where I would consider flush. So have been running 15mm spacers all round have have been much happier with that. But its always annoyed me running spacers when I should have that as dish.
Since I've been getting rub on my swaybar from increased steering lock, I decided to go for the similar specs, but smaler overall diameter so I can get more lock. Want to stick with stock body lines.
http://www.willtheyfit.com/index.php...et2=16#content
Manji is offline   Reply With Quote
The Following User Says Thank You to Manji For This Useful Post:
M23 (12-22-2014)
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 05:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 07:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-28-2012 12:20 AM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 09:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
