Old 01-28-2013, 05:59 PM   #29
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by foney_email View Post
What brand led did you get that fades? I would be interested as that sounds much better than my alternatives now.
The problem is that even though some of the current LED domelight offerings do fade, none of them fade in the linear fashion and for the same length of time as the stock incandescent. Mine solves this issue the right way.
-Acree
Acree is offline   Reply With Quote
Old 01-28-2013, 06:09 PM   #30
foney_email
foney_email's Avatar
I see. I know you're not at the finished stage yet, but what are you thinking for a price?
foney_email is offline   Reply With Quote
Old 01-28-2013, 07:17 PM   #31
Acree
Acree's Avatar
It is tough to say at this point. It is worth mentioning that is not just a board with a couple of wires coming out of it that you plug in place of the stock bulb. This is a full dome light assembly retrofit.
-Acree
Old 01-28-2013, 09:43 PM   #32
maximumdose
Drives: 2013 Firestorm FR-S
Hugely interested! I'll keep an eye out =)
maximumdose is offline   Reply With Quote
Old 01-29-2013, 01:16 AM   #33
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
Red-Orange
I put two under the footwells to match the bright orange of the Bespoke stereo - it looks great. my dome is still white but I was thinking that would go same color as well soon --
rikdrt1 is offline   Reply With Quote
Old 02-20-2013, 10:26 AM   #34
Acree
Acree's Avatar
I just wanted to update this thread. I finally finished the prototype! The thread can be found here.
-Acree
Old 02-20-2013, 11:39 AM   #35
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I say, looks great. Too bad my footwell kit is prewired to my dome, but if i figure out a fix then i may b all over this if the price is right
lbroskee is offline   Reply With Quote
Old 02-20-2013, 12:23 PM   #36
Acree
Acree's Avatar
I guarantee you I can come up with a way to make both work together.
-Acree
Old 02-20-2013, 12:34 PM   #37
lbroskee
lbroskee's Avatar
-Acree
I'm runnin the phastek 2 dome pad setup, so if u find a way im all ears lol
Old 02-20-2013, 12:41 PM   #38
Acree
Acree's Avatar
They simply provide power and ground through a pass through harness. It's literally 2 connections. I could make my retrofit plug and play with that kit in 30 seconds.
-Acree
Old 02-20-2013, 05:52 PM   #39
lbroskee
lbroskee's Avatar
Halfway down there is a split so as long as i can easily tap into this power safely it should work easy
Old 02-20-2013, 06:31 PM   #40
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I say the blue lighting Acree is working on, plus maybe a trip to a shop that does upholstery and see if you can have that stitching replaced with blue. I'm thinking about doing it with my car to match better.
Nevermore is offline   Reply With Quote
Old 02-21-2013, 04:04 PM   #41
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I just thought I might add some more confusion to the fray. I installed the Precision LED's red LED interior dome light in my car. Personally I love it and it highlights the red accents in the interior.
Also, and more importantly, it fades in and out every bit as well as the stock incandescent.
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
tripjammer (02-21-2013)
Search this Thread:
Advanced Search
Catch Can Debate wootwoot Engine, Exhaust, Transmission 141 06-08-2017 02:12 PM
Cosworth Internal Upgrades Confirmed DanPO Engine, Exhaust, Transmission 60 05-26-2015 06:45 PM
BRZ vs FRS - The Debate TAP Auto Parts Scion FR-S / Toyota 86 GT86 General Forum 139 05-07-2013 07:26 PM
The Great Hatch vs Trunk Debate nate89 Scion FR-S / Toyota 86 GT86 General Forum 229 10-24-2011 10:39 AM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 06:24 PM
