Old 01-21-2013, 01:31 AM   #15
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Originally Posted by EK_Golfer View Post
My FRS is starting to show the same wear in those "foam" parts. I purchased the car only 3 weeks ago.
yeah my driver side is a bit better looking then right side.. i just have this little chunk some how come off..theres another little chunk on top/bottom of that hole chunk..i just put a pin drop of super glue to hold it down.. going to put a rubber silicone thing on and patch that hole
not sure why they made it out of foam instead of a rubber base that im sure it will last way longer..i think this has to be the cheapest part of the car..
plasti dip it anyone? will that hurt the foam ?
going to grab some after work tomorrow need to do my rims might test it out and see.
Old 01-21-2013, 01:40 AM   #16
CTB727
Drives: 2013 Subaru BRZ
Don't waste your time. It'll just "cover up" the problem like sweeping it under a rug. Sooner or later, it'll get worse.
CTB727 is offline   Reply With Quote
Old 01-21-2013, 10:18 AM   #17
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
does this happen to BRZ owners?
chenshuo is offline   Reply With Quote
Old 01-21-2013, 10:24 AM   #18
microbionic
microbionic's Avatar
yes.
microbionic is offline   Reply With Quote
Old 01-21-2013, 02:03 PM   #19
marky
marky's Avatar
Yeah im having second thoughts on applying dip on it.. might damage it when I peel it off..ill just leave it alone and be careful of it not making it worse ..
Old 01-21-2013, 02:26 PM   #20
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Only reason I could think of in regards to why they don't use "rubber" is because of the friction and the sound it'll create when opening and closing the frameless windows.
As for that gouge, it looks like one of your passengers accidently dug their nail into it while trying to open the door by the window?
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 01-21-2013, 02:31 PM   #21
marky
marky's Avatar
Originally Posted by DaJo View Post
Only reason I could think of in regards to why they don't use "rubber" is because of the friction and the sound it'll create when opening and closing the frameless window.
I believe the front of the window has a rubber thing next to the small little window..yeah might make sound or rub against it causing damage to the electric motor.. but it could of been made with a more durable material not a cheap foam..
Old 01-21-2013, 07:39 PM   #22
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
I checked other cars such as my brother's 2000 Lexus ES, it also uses a foam material on the inside of the door frame just like the FRS, so it looks like Toyota has used this material before. Not sure if this make us feel any better but it's good to know it's not the first time they've used it.
EK_Golfer is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 11:20 AM
interior illumination kit and side window visor davey90 AUSTRALIA 40 05-07-2013 10:49 AM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 01:32 AM
Foam Gun: Necessary? Re~Mix Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 06-24-2012 11:45 PM
