#15 |
I think we're getting at the same point from different perspectives :p
#16 | |
Kuruma Otaku
You can't 'add downforce' with a giant wing if the net lift is still positive. It may seem like semantics but it's important to think of the whole system.
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | ayau (01-20-2013) |
#17 |
Drives: Some rust bucket
Is it safe to assume that the FRS/BRZ has negative net lift? If there was positive lift, then the tires would lose more traction as speeds increased.
#18 |
Kuruma Otaku
Almost all cars generate positive lift.
Because titanium. |
| The Following 2 Users Say Thank You to Dimman For This Useful Post: | ayau (01-20-2013), SomeoneWhoIsntMe (11-03-2014) |
#19 |
#20 |
In @CSG Mike's s2000 CR example, he said that the BRZ could take the sweeper faster in the BRZ than in the CR. Keep in mind that the CR has wider tires and front and rear aero.
CR: ![]() Based on this, it appears that the CR could potentially generate more lift than the BRZ even with all the "downforce" parts. I wonder how a base S2000 would handle on the same sweeper.
#21 |
My unsubstantiated belief based only on anecdotal evidence is that the BRZ generates less rear lift than the my CR.
Honda's own documentation states that the CR wing eliminates 70% of rear lift [with hardtop]. The front of the s2k is proven to make substantial downforce via windtunnel testing. |
#22 | |
Kuruma Otaku
Keep in mind that all aero lift does is change loading on tires at speed. Tires generate grip based on load. So balancing which end of the car sees more or less load from aero affects under/oversteer relative to speed.
Because titanium. |
#23 | |
#24 |
Thanks for the clarification.
I still wonder if the OEM "diffuser" is actually decreasing lift, or if it's just there for aesthetics. For a sub 30k car, I have a feeling it's the latter. Even something like the OEM diffuser is probably for aesthetic purposes as well.
#25 | |
Kuruma Otaku
http://www.c-westusa.com/labs/fudo1_s2000spec.asp But it does show that you can get a lift AND drag reduction with a good package.
Because titanium. |
#26 |
This makes sense now when you say that most cars will generate lift. The shape of a car is similar to the shape of an airplane wing. The air above the car has to travel a longer distance than the air below the car. This pressure difference generates lift.
[ame="http://www.youtube.com/watch?v=YQwh2fdfYiM"]Audi: Aerodynamics of planes and cars - YouTube[/ame] |
| The Following User Says Thank You to ayau For This Useful Post: | Bristecom (04-01-2013) |
#27 |
So in theory, if you install panels underneath the vehicle and speed up airflow, then the net result should be an increase in lift. However, if you have a rear diffuser, then that should reduce lift. Is this correct?
#28 | |
from http://www.maxrev.net/site/index.php...blog&Itemid=54 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | WillRacer1jz (01-21-2013) |
| Front aerodynamics... need help! | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 10-23-2012 10:27 PM |
| Interesting aerodynamics differences between USDM, JDM, etc. | yargk | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 09-20-2012 05:00 PM |
| Coefficient Drag & Aftermarket Aerodynamics | FT-86GOD | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-28-2012 02:20 AM |
| Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained | Moshpit37 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-26-2012 10:19 PM |
| Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained | Moshpit37 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 06-21-2012 01:47 PM |
