#29 | |
Drives: 2018 Camry XSE V6
Apparently there is a DIY for your perceived backwards shifting. Personally, I like it the way it is, but, each to their own preference. |
#30 |
#31 | |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
| The Following 2 Users Say Thank You to zoomzoomers For This Useful Post: | akyp (01-20-2013), Demandred7 (01-18-2013) |
#32 | |
![]() I guess I need to drive more powerful cars.
#33 | |
Drives: 2013 FR-S AT Argento
The owners manual in describing sport mode states "lower gears are used and gears change at a higher engine speed." It also states the obvious that sport mode controls are not carried out while in manual mode. No mention of quicker shifts and throttle response. But, the owners manual glosses over a lot of details. I can't find anything that says whether or not the quicker shift times and throttle response of sport mode are also utilized in manual mode. Without yet having tried to discern this for myself, I would guess that manual mode works in one way without regard as to whether it is activated from normal mode or sport mode, and that manual mode would always take advantage of the quicker shift times and throttle response. I suppose the shift response in manual mode could change depending on whether sport mode is on or off. Or maybe it only makes a difference while in temporary manual mode. I rather doubt all that. I'll have to wait a week to compare the different modes so as not to disrupt my religious vow to drive only in manual mode all week. Has anybody found documentation or had a clear experience to determine if manual shift mode utilizes the quicker shift times and throttle response of sport mode? |
#34 |
86DESU
Drives: 86 GTS, S13, CB9
Sport VSC == Vehicle stability control and throttle response, so it's seperate to "Sport" mode on the transmission. this is one of the few cars left where the transmission isn't controlled by the ECU directly. Two seperate brains! I've driven some older cars the same with a "sport" mode for the traction control and a seperate brain for the engine-- Turning on "Sport" traction control/power delivery and "winter" on the trans confused the shit out of a turbo Volvo.
![]() (So you know, manual cars have the sport VSC and traction control buttons) |
#35 |
Drives: Scion FRS Ht Lva(AT)
I wish that the gear you are in would also show in addition to "D" when in drive. That would allow better use of paddles especially for downshifts when you want to get into the torque band.
The trick to using the paddles when doing sharp turns where the paddles may be out of position is to upshift early before you start to turn. 1rst gear is really probably lower than it needs to for the engine(uses a lot of fuel), whereas the engine can pull easily in 2nd. |
| The Following User Says Thank You to smbrm For This Useful Post: | Ocala FR-S (01-19-2013) |
#36 | |
#37 | |
So far I'm opting for the late upshift on slow turns after the wheel returns to near straight ahead. I'll try the early shift and see how that goes. |
#38 | |
At WOT on a straight away, or downshifting for engine braking, the paddles start to make more sense. |
| The Following User Says Thank You to Demandred7 For This Useful Post: | Ocala FR-S (01-19-2013) |
#39 |
AutoX-10/10ths every run
This is only true in Manual mode. In Auto mode you can use the paddle shifters (but not the stick) to initiate shifts.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#40 | |
| The Following User Says Thank You to whataboutbob For This Useful Post: | Ocala FR-S (01-19-2013) |
#41 | |
#42 |
Drives: 2013 Ultra Marine Blue FR-S
I had paddle shfters/shifter in my Ralliart, and you'll eventually learn to just use both. I was upshifting with the paddles sometimes when grabbing something with my left hand (always drove it in manual mode and mainly use knob shifter). It's definitely more fun to drive in manual mode. And as for the knob shifter, I woud have thought up shifting would have been cicking it down, and down shifting would be up, like on my Ralliart, but I guess not. Interesting.
| AT Manual Mode Easter Egg? | whataboutbob | Engine, Exhaust, Transmission | 2 | 12-14-2012 12:03 PM |
| hard shifting in sport mode AT | sofrsnsokleen | Issues | Warranty | Recalls / TSB | 11 | 12-12-2012 12:13 PM |
| AT Manual Mode Downshifting | Reprobate | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 07-23-2012 12:40 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
| snow mode = girlfriend mode? | Nepenthe | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 07-01-2012 04:02 PM |
