| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 | |
Drives: 2012 honda civic ex
#58 | |
#59 |
Hmmm, well I have not heard definitively from any of the shops that have autos if they are seeing that (shops like P&L Mortorsports, FA20club.com, etc that actually have autos for shop cars) 10whp loss you claim. Let's just say I'm very skeptical, but open minded...
Also, Sport-Tech is right, the gearing is more noticeable in higher gears, but in the lower gears, not as much. The lower gears are the gears you will use on a track 99% of the time and the gears that matter for performance. I think the 5-60 (no launch) motortrend test between the two is telling, only one tenth of a second difference in acceleration with no launch required. But yes, I did say 2-6 would be nearly identical and I should have said "2-4 will be very similar". |
#60 | |
so that gear box would find appeal to a broader group of people! after my experience,i am happy it gets better gas mileage,WITHOUT losing the fun aspect of the vehicle! |
#61 | ||
as you down shift. THIS car does not suffer with this auto tranny. |
#62 | |
Now w/ over 400 womprats!
Drives: BRZ LZR
![]() And there were definitely some cones that were laid to rest...
- The Ancient BRZ Sacrament by Zaku |
#63 | |
Drives: TBD
Torque trough lies between 3-4.4K (see below): To correct my earlier comment, you actually never really get into the torque trough with either tranny on a redline upshift except for the 1-2 shift on the auto, but you do always lose more power on upshifts with the auto (see relative speed vs rpms for the auto vs the manual below). And you get closer to the torque trough on the 2-3 auto upshift (at 4900 rpm) than on the higher-speed 3-4 or 4-5 shifts (5200 rpm for both). The manual drops down to only 5800 on the 3-4 upshift - less loss of power. It's also 300 rpm better on the 2-3 upshift, and 900 rpm better on the 4-5 upshift. |
#64 |
Good data, but we can agree to disagree. The "real" difference of a 1/2 second you mention is in fact not real. The real measured difference is a tenth of a second as measured. You and I do not know how fast the motortrend driver shifted the MT. Not a safe assumption you are making!!
You could also argue the longer gears in AT the car wont be shifting as much which might help on certain autox or road courses. Ironically, power isnt the point of this car. Balance is. In a straight line if you can get a 1.7 or 1.8 60' in a MT during a 1/4 mile run and a 2.2 - 2.5 60' in a AT... Thats over a second on the end of the run. Right about the diff between both in many of the tests. Thats why I think it is mainly the launch. |
| The Following User Says Thank You to Captain Insano For This Useful Post: | jmaryt (01-18-2013) |
#65 |
First 86
Drives: Scion FRS Argento Automatic
It would be interesting to see a 0-60 comparison with a rolling start.
Life is short...NO BORING CARS |
#66 |
The motortrend 5-60... that is from a rolling start.
#67 | |
You know you want it.
Drives: '13 FR-S
Automatic FR-S Zero to 60 mph: 8.1 sec Zero to 100 mph: 21.4 sec Rolling start, 5–60 mph: 8.2 sec Auto mode, 30–50 mph: 4.1 sec Auto mode, 50–70 mph: 5.3 sec Standing ¼-mile: 16.3 sec @ 90 mph Top speed (drag limited): 125 mph Source Manual FR-S Zero to 60 mph: 6.4 sec Zero to 100 mph: 16.6 sec Rolling start, 5–60 mph: 8.1 sec Top gear, 30–50 mph: 13.1 sec Top gear, 50–70 mph: 10.3 sec Standing ¼-mile: 14.9 sec @ 95 mph Top speed (drag limited): 136 mph Source(PDF) These numbers are from Car and Driver. When a launch is factored out, the difference in acceleration times to 60 are minimal. The auto's taller gears do put it at a disadvantage at the car's upper speed limit. The disparity between the 0-100 times is a bit surprising given what they recorded for the quarter miles. *shrug* Then again the auto runs out of energy 11 miles per hour earlier.
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
#68 |
First 86
The top speed for the auto was in "auto mode", I wonder if it was kept in 5th gear in manual mode if you could get a higher top speed. Maybe have to do a "personal" test.
#69 |
I also wonder how they drove the AT when those times/speeds were taken. Did they put it in sport mode and let car do shifting? Complete auto mode without sport? Did they shift manually? Any of those make a difference. On the flip side, when the MT was driven we don't know how good or bad of a shifter the driver was.
#70 |
i would assume also,it would make a difference,perhaps really noticeable juggling the different modes.
| Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) -- General Topics | 59 | 12-01-2013 01:28 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
