86WORX
Old 01-23-2013, 01:04 PM   #15
Originally Posted by JoeBoxer View Post
I like the 300v a lot but just wondering if its overkill since i don't ever get the oil really hot at the track or anything.
You want to prep your car for the harshest condition it will ever be exposed to. Doing it once is just as hard on the car as doing it 20 times.
The only way to really know is to do a used oil analysis on your current oil.
JoeBoxer (01-23-2013)
Old 03-24-2016, 02:55 PM   #16
deafwiggle
deafwiggle's Avatar
Drives: '14 Scion FR-S; '93 JDM MR2 T
The 300 works in both the trans and diff. However, we use the 300LS in our diff, only because we like the lockup characteristic better. Both will protect the diff just fine.
I know this is an old thread, but I've been trying to figure out whether to use Motul LS in the diff. You say "we like the lockup characteristic better". How is it different from using the non-LS lube? Is TBR affected? If so, in which direction?
Thanks for any clarifications...
Dirk
'14 FR-S; '93 JDM MR2 T
Rippin' it. ...old and new school
deafwiggle is offline   Reply With Quote
Old 03-24-2016, 03:41 PM   #17
Dirk
The actual viscosity of the fluid is different. The LS is not necessary at all, but if you don't mind experimenting, its only a few bucks.
For that matter I prefer Gear Comp in the differential over Gear300LS, but that's another ~5 bucks or so per liter.
Old 03-24-2016, 03:52 PM   #18
deafwiggle
deafwiggle's Avatar
I very much appreciate your prompt response, Mike; thanks!
However, that didn't answer my question: What is the difference in diff behaviour between LS vs non-LS? (I like how the diff behaves with the stock fluid and would prefer that this not be altered significantly.)
Cheers!
Dirk
Old 03-24-2016, 06:44 PM   #19
Cheers!
Dirk
The Torsen hangs on just a hair longer before it "gives up" and lets the inside wheel spin on hard cornering. Yes, the torsen is mechanical, but changing the fluid does make a difference.
ruturaj001 (07-11-2023)
Old 03-24-2016, 11:51 PM   #20
deafwiggle
deafwiggle's Avatar
There's the answer I was looking for. LS it is... Thanks, Mike!
Cheers!
Dirk
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 04:02 PM
Motul fluids Filipino Royale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 88 04-20-2014 10:36 PM
motul Oil whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-24-2013 11:12 AM
Delete driver01 CANADA 5 08-30-2012 05:58 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 01:46 AM
