CANADA Canada
Old 01-21-2013, 06:13 PM   #43
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Originally Posted by wparsons View Post
5whp gained on the stock tune with no difference other than 94 octane vs 91 octane? No offense, but I call BS on that. That's a bigger gain than most exhausts.
I would believe you could gain 5whp by adjusting the tune to take advantage of the higher octane, but on the stock tune I see no way you're gaining 5whp from higher octane unless you were running less than 91 on the first runs.
Call it bullshit if you want we did the test. First run on 91, second on 87 and then 94. If you read french go read this if not then google translate it
http://www.quebecfrs.com/forums/view...php?f=6&p=2962
http://www.burn-out.ca/content/scion...ne-test%C3%A9s
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
The Following User Says Thank You to WatchmaN For This Useful Post:
Future (01-22-2013)
Old 01-22-2013, 01:00 PM   #44
wparsons
wparsons's Avatar
Was the car driven enough between runs for the ECU to adjust? Was the tank totally drained before adding the new fuel?
Any data logs to see what the ECU was doing with different grades?
Did you only do a single pull with each octane rating, or did you do at least three of each to get a good average?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
7thgear (01-22-2013)
Old 01-22-2013, 07:10 PM   #45
Future
Future's Avatar
Drives: BRZ!
google translate? http://translate.google.com/translat...3D2962&act=url
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 01-30-2013, 03:23 AM   #46
MiniGuy
Drives: 2013 Subaru BRZ SS Sporttech 6sp.
Originally Posted by grgonium View Post
For those of you getting 400 - 600+ kms per tank ... how much of it is Highway, and is your car MT or AT?
For some reason I'm only getting 320-380 kms per tank. (filling up as soon as the light goes on, on the higher end)
I drive ALL city, mostly traffic, and lots of stop lights. Could have an effect?
I am in Vancouver and I feel your pain. I am stop and go traffic most of the time and struggle to get 400k from a tank. You have to get out and cruise the open road to get better mileage. This is my daily driver (MT) and I love it but better MPG l/100k would be nice.
MiniGuy is offline   Reply With Quote
Old 02-01-2013, 02:29 PM   #47
fenton
The FRS manual specifically calls for 93-94 octane. The ECU is designed to use the highest ignition timing if it can, for that it needs 94. 91 is the bare minimum.
Yes it works fine on 91 but you wont get the same performance.
I use Husky 94 almost exclusively and my mileage will range from about 450 to 600 depending on how i drive.
If i drive like a mad man i get about 450 if i drive nice i get 600.
See my fuelly
https://www.fuelly.com/driver/fenton108/frs
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Gords_zenith (03-05-2013)
Old 02-01-2013, 03:27 PM   #48
BioRage
Drives: ~_~
See my fuelly
But... but.. Airmiles>PetroPoints
Join us! @ EightSixClub
BioRage is offline   Reply With Quote
Old 02-01-2013, 04:20 PM   #49
fenton
I use the husky loyalty card plus the husky mastercard.
2 x points for getting premium, another 2x points for using mastercard.
1$ = 1 point
55$ fill x 2 x 2 = 220 points a fill
700 points gets you 5 bucks off.
Plus when i use my MC for other purchases i still get 1 point.
Since i got the card i get 5 or 10 bucks off each fill. Been making some large purchases on the card but still, adds up fast
Old 02-01-2013, 04:34 PM   #50
wbradley
Sarcastic SOB
wbradley's Avatar
Too bad the few Husky stations I have seen in ON only sell lower octane fuel and have been known to cause runon/knock in the past.
Old 02-01-2013, 04:48 PM   #51
fenton
Weird. Every Husky station in Calgary has 94 octane that i have found. Petro is just starting to get 94 in some of their stations.
As far as the power differential look at the difference when applied to a modern BMW engine.
See here for DYNO and ignition advance. Maybe i will get out and log something like this with the FRS>
http://www.westernsubaruclub.com/smf...?topic=28920.0
wbradley (02-01-2013)
Old 02-01-2013, 05:01 PM   #52
BioRage
Drives: ~_~
Lol all our petro's have 94 :P
Old 02-01-2013, 05:51 PM   #53
wparsons
wparsons's Avatar
^^ Not all do, a good percentage still top out at 91 octane.
flickr
Old 02-01-2013, 09:20 PM   #54
roddy
roddy's Avatar
Drives: '13 Ultramarine
Around here, the only Petro stations that have 94 are the ones that used to be Sunoco stations.
Old 02-01-2013, 11:29 PM   #55
whitejdm
Drives: BRZ prem.
Not sure on petrocan 94 but I know husky's 94 octane comes from the ethanol content and I'll take 91 with no ethanol any day.
whitejdm is offline   Reply With Quote
Old 02-01-2013, 11:45 PM   #56
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
isnt Husky owned by Shell? so does it use Shell gas?
chenshuo is offline   Reply With Quote
Search this Thread:
Advanced Search
Heads up, you can get 20 Cents off gas from Shell if you have a Ralphs Reward card jflogerzi Southern California 4 12-27-2012 03:47 AM
Petrocanada 94 or shell 91? QC-FRS CANADA 24 06-18-2012 05:55 PM
