#29 | |
No we don't have a shock dyno to quantify the damping change in every click through the adjustment range. However, I'd venture that my butt dyno is an effective, albeit crude tool for measuring the change As with any other mechanical component on the car, dampers are a wear and tear item. That's why rebuild/revalve services are offered, at least for the Teins. As we both know, tolerances and guidelines for aircraft are significantly stricter than cars... Last edited by CSG Mike; 01-11-2013 at 07:15 PM. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | wu_dot_com (01-11-2013) |
#30 | |
This is on stock suspension, which has a TON of droop, as you can imagine. |
#31 |
Duh, don't run over the curbs.
| The Following User Says Thank You to xwd For This Useful Post: | CSG Mike (01-11-2013) |
#32 | |
i dont know if the edfc would be able to fix that in any capacity because it seems to make adjustments based on an accelerometer in the car so i dont think it would be able to help with the curb thing in any capacity, let alone as good simple mechanical solutions. |
#33 |
Grrr, there no pics of the BRZ at that same turn. This is a perfect example of where active damping can assist.
With my "normal" track setting ( 5 compression, 6 rebound) , I get the same result, where two wheels lift, and I'm effectively putting no power down. Landing form that always results in a little bit of looseness; I'm WOT before I catch the air, and I'm WOT when I land (poor diff...) During testing, we did note that anything softer than 8 on rebound resulted in no air. We'll ignore crosstalk for this example; it's there but not significant enough to matter here, and we were trying a relatively small range of settings during fine tuning. |
#34 | |
Drives: 2013 FR-S Ultramarine
Nathan |
#35 | |
#36 |
Drives: '13 GBS Subaru BRZ
It doesn't. It's only adjusting based on acceleration/deceleration, and speed (if you have the GPS add on.)
#37 | |
Ideally, I'd like to be able to dial it in by GPS location... but that's not listed as a feature |
#38 | |
On a side note, we're on stock sways. Our car is VERY simple... you could sum it up as coilvers, brakes, rims, tires, axleback. Nothing else. No bracing, bushings, gutting, weight reduction, etc. |
#39 |
well ill be looking forward to the results. especially since your car seems to be about the things i value (the whole moderation, balance, fun, connection ect.)
#40 |
Drives: 86 GTS
Kind of an oddly missing feature. I would have thought that with GPS and accelerometers some sort of track mapping feature so you could change the settings for entry and exit of each corner on a mapped track would really open up the potential.
#41 |
Drives: 2014 Widebody Cosworth FR-S
When I first heard about this, I fantasized about it using GPS and a G-sensor with some logic. For example, as you go round and round the track and the suspension is adjusting, it will remember the settings from the last lap and each corner and make adjustments to achieve greater and greater G's though a particular corner. Basically trying to find you the best setting per any given corner, assuming that the line is the same lol. A boy can dream
![]() Thanks, Rick |
#42 |
I think some people are developing unreasonable expectations for this product, especially in its price range.
From reading all the descriptions it looks like all the GPS does is allow adjustments based on speed. Im not sure why they didn't just connect to the OBDII port like Tanabe's system does. Feeding location data and adjusting settings based on track position is orders of maganatude more complex then what this product seems to do. 3d Accelerometers would be great too, but would require tons of fine tuning for the specific car if you wanted it to react to ever bump and dip in the road. Every car would respond differently and I doubt the servos could even adjust quickly enough to be effective. This is why newer high end systems use rheomagnetic dampers because they can adjust almost instantly. I'm looking forward to this system for what it is, if you're looking for more then I would get used to disappointment.
| Tein MonoFlex | Kenno | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-18-2015 02:17 PM |
| Frs on Tein S-Tech springs | Juanito08 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 75 | 10-23-2015 12:19 AM |
| Tein Street Advance Available | 86drift | Australia Classifieds | 26 | 02-06-2013 12:31 AM |
| eibach pro kit vs tein H tech | lbroskee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 10-04-2012 01:11 AM |
