86WORX
Old 01-14-2013, 04:36 PM   #43
donutfilling
donutfilling's Avatar
Drives: frs
Is there any reason you would not recommend the JRZ RS1 over the JRZ RZ even thou they are monotube like the SRC and the pros? Interested in why as racecomp seems to recommend the rs1 over the rs.
donutfilling is offline   Reply With Quote
Old 01-14-2013, 05:14 PM   #44
The RS1 is a 1-way adjustable damper. While that one adjustment changes both compression AND rebound, it may not be able to provide the fine adjustment that our hardcore clients may prefer.
If you want something with simple adjustability, then the RS1 may be perfect for your needs.
Given that the SRC is geared toward a more performance oriented crowd who tends to be more open to playing around with settings, I would steer them toward the RS or RS-Pro for comparison.
The RS1 is something closer to a Ohlins DFV. Solid brand, solid quality, but single adjustable for ease. You can't go wrong with them, but my personal preference is to have more control over my damper adjustments.
donutfilling (01-14-2013)
Old 01-14-2013, 05:24 PM   #45
Racecomp Engineering
We recommend the RS1 over the RS because we have spent quite a bit of time with both dampers and found the RS1 to simply be the better performing damper. The RS1 is a single adjustable monotube while the RS is a double adjustable twintube. JRZ does a much better job with monotubes than they do twintubes. You do give up the double adjustable damping though, which is why the RS Pro is the best of both worlds (but they cost quite a bit more, more than these Teins IIRC).
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (01-14-2013), donutfilling (01-14-2013), RYU (01-14-2013)
Old 01-18-2013, 06:55 PM   #46
Hanakuso
Do the helper springs come included in the base price or is that an extra/optional fee?
Hanakuso is offline   Reply With Quote
Old 01-18-2013, 07:14 PM   #47
Helpers are included for the rears (don't need them in the front).
Hanakuso (01-18-2013)
Old 01-20-2013, 07:06 AM   #48
eckoflyte
Drives: Toyota 86 GTS
Would the vorshlag or ground control camber tops work with this setup?
eckoflyte is offline   Reply With Quote
Old 01-20-2013, 09:02 PM   #49
CSG David
CSG David's Avatar
The TEIN SRC comes with its own front camber plates designed specifically for that setup.
Old 01-21-2013, 02:42 AM   #50
Camber plates are included, but if you'd like to use your own, you're more than welcome to (but you'll have an extra set of Tein camber plates...)
Old 01-25-2013, 04:47 PM   #51
CSG David
CSG David's Avatar
Just wanted to show how much roll you get with just these coilovers alone. Everything else suspension wise is OEM. Check out that flat cornering!
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Anthonytpt (04-26-2013), RYU (01-25-2013)
Old 01-29-2013, 02:10 AM   #52
D1cker
Drives: B9 S4/ND2
I just wanted to revive this thread to tell you guys how great these things are. I installed them today and had them aligned and the car is transformed into a completely different car compared to the GC kit I had on it before.
The ride is on par with the KW's (which have a much lower spring rate and less control at the limit) and very comfortable, even over the horrible pavement that is the 55 FWY when going over edinger (think whoops in motocross).
The handling balance is excellent and the control over bumps is superb (compared to the GC kit ad the V3's)
I'll try to post more as I drive the car more, but as of right now, this is the best suspension I have owned, and worth every penny (and I'm a cheap bastard)
Big shout out to CSG Mike for helping me get a hold of them at a great deal and to Emerson at TEIN for the install and alignment.
D1cker is offline   Reply With Quote
The Following 5 Users Say Thank You to D1cker For This Useful Post:
B L U E S L A T E (02-01-2013), CounterSpace Garage (02-04-2013), juliog (04-18-2013), RYU (01-29-2013), wparsons (09-16-2014)
Old 01-29-2013, 04:56 PM   #53
RYU
RYU's Avatar
Drives: really slow...
Wish I had more $$ for these bad boys
RYU is offline   Reply With Quote
Old 03-08-2013, 01:53 PM   #54
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Updated OP with this video...
[ame="http://www.youtube.com/watch?v=nGBZWkoQO-s"]CSG BRZ Buttonwillow 2:00 lap - YouTube[/ame]
CounterSpace Garage is offline   Reply With Quote
The Following 4 Users Say Thank You to CounterSpace Garage For This Useful Post:
B L U E S L A T E (03-27-2013), djdnz (03-08-2013), NorCalRider (03-30-2013), zoomzoomers (03-09-2013)
Old 03-27-2013, 08:43 PM   #55
B L U E S L A T E
Drives: BMW E84
Finally installed these on my BRZ over the weekend and had taken some photos that I wanted to share with everyone.
B L U E S L A T E is offline   Reply With Quote
The Following 3 Users Say Thank You to B L U E S L A T E For This Useful Post:
Anthonytpt (04-26-2013), CSG Mike (03-27-2013), Hicklinc (05-17-2016)
Old 03-27-2013, 10:33 PM   #56
xwd
Does anyone have any shok dynos for these?
Tein H Tech installed pics and review JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 05-19-2013 01:22 PM
Enjuku Racing - Tein S-Tech Springs - ** ON THE SHELF ** Enjuku Racing Brakes, Suspension, Chassis 0 08-14-2012 06:06 PM
CUSCO|TEIN|KW|EIBACH|BC RACING & More! All your Suspension Needs @ Echelon Autosports Echelon Autosports Brakes, Suspension, Chassis 10 07-28-2012 02:27 PM
Subaru BRZ to compete in Super GT Racing Championship next year poormans_LFA BRZ First-Gen (2012+) -- General Topics 18 11-21-2011 09:29 AM
