86WORX
Old 06-01-2014, 12:16 AM   #883
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by Scooby South View Post
Nahhh don't think so..
14.2 BODYWORK
F. Parts must be installed as directed by the manufacturer. Exact replicas,including weight, from alternate sources are also permitted.
Bill
Well in that case I may pick up a front lip. I'm getting tired of having to continuously rub off that rubber residue every time I was the car.
was385 is offline   Reply With Quote
The Following 2 Users Say Thank You to was385 For This Useful Post:
Scooby South (06-01-2014), Turkish (06-01-2014)
Old 06-01-2014, 01:48 AM   #884
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Then wouldn't that make the Whiteline diff cradle inserts illegal since it also adds a big metal plate? Wait, is it illegal!?
Not likely .... way to much metal ...
14.8 Suspension:
D. Differential mount bushings may be replaced but must attach in the standard location(s) without additional modification or changes. Differential position may not be changed. The amount of metal in a replacement bushing may not be increased relative to the amount of metal found in a standard bushing for the particular application. Solid metal bushings are specifically prohibited.
Bill
RiskyTrousers is offline   Reply With Quote
Old 06-01-2014, 12:11 PM   #885
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
No.. not exactly.. The cusco ones are almost solid metal.. and we are talking about 2 different bushings here...
The Whitelines have 'washers' to hold them in.. and they are 99% urethane and the go on Diff mount on subframe.
Bill
Scooby South is offline   Reply With Quote
Old 06-02-2014, 07:09 PM   #886
mrazny
Drives: BMW 135i, soon to BRZ
14.2 BODYWORK
Bill
That's the Blue Series stuff, right? I'm still of the hopeful mindset that you won't even have someone challenge that in class, but if they do it's on the basis of "model". Though model does start down the road of "appearance" as a signifier of difference, ST already has the clarification that all parts of a 3-series generation is considered the same model. AKA it's why the 325's and 328's have M3 bumpers. That can only guide the PC though, and isn't official. Might be ripe for a clarification just in case of weeny protests.
mrazny is offline   Reply With Quote
The Following User Says Thank You to mrazny For This Useful Post:
Scooby South (06-02-2014)
Old 06-02-2014, 07:19 PM   #887
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
For STX with no power mods do you guys recommend to stay with a 245/40/17 on a 8" wheel or a 255/40/17 on a 9" wheel?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-02-2014, 07:34 PM   #888
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
If you're buying new wheels, go with the 9s. If you're already on the 8s, dont spend the money until you're well acquainted.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 06-02-2014, 07:41 PM   #889
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
How do y'all feel about wheel spacers? Specifically, I'm considering 5mm on all four wheels. Will I need longer studs to be safe for autocross or will oem be fine? I'm currently using the stock wheels until I can afford rims and tires.
Sent from my SM-G900V using Tapatalk
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 06-02-2014, 08:06 PM   #890
Kido1986
Dodging cones
Kido1986's Avatar
5mm is iffy at best on our studs. I get about 6-7 full turns of engagement with 3mm. If you cannot make 5 full turns MINIMUM, don't drive it. A seasoned driver lost a wheel in Atlanta (350z) because of thread engagement after a spacer.
The Following 2 Users Say Thank You to Kido1986 For This Useful Post:
Scooby South (06-02-2014), Turkish (06-02-2014)
Old 06-02-2014, 08:45 PM   #891
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
I would stay away from 5mm. I tried a 5mm spacer with a set of 17x9 Rota DPT wheels and felt really uncomfortable when I could only get 3.5 revolutions with a hand tighten. 3mm was just enough for breathing room w/ stock spring perch and 255 RS-3s.
3mm gave me 6+ revolutions with a hand tight plus maybe 1 more after torqueing the lugs.
AyJay is offline   Reply With Quote
The Following User Says Thank You to AyJay For This Useful Post:
Old 06-02-2014, 09:08 PM   #892
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I run 5mm spacers but I have 10mm extended studs. It was a worthwhile upgrade.
Old 06-02-2014, 10:10 PM   #893
Scooby South
Conedancer
agreed.. just finished up putting my ARP's on.. and definitely a worthwhile upgrade..
Bill
Old 06-03-2014, 02:24 PM   #894
BRZZZZZZZZZZ
Car Nut
I'm running 16X7s with 225s now so I would be looking at 17X9s with 255s next I think.
Old 06-03-2014, 02:30 PM   #895
Kido1986
Dodging cones
Kido1986's Avatar
I'd still say wear out the set of tires you're on first, unless throwing around $1500 for wheels and tires is easy money for you (I'm a poor SoB lol)
Old 06-03-2014, 02:34 PM   #896
BRZZZZZZZZZZ
Car Nut
My RS-3s are less than 25% tread right now so its time anyway, I will recoup around $1000 for my Volks most likely.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
