#3291 | |
If they’re OE rotors, you have holes which you can put a bolt through and slowly wrench. The bolt pushes against the hub face and will force the rotor off. Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | smg1138 (05-10-2018) |
#3292 |
Drives: '22 BRZ
hit it with your purse
| The Following 4 Users Say Thank You to DocWalt For This Useful Post: |
#3293 |
Drives: 2013 Raven FR-S
#3294 |
M8 X 1.25 Bolt IIRC
Kyle H. - #89 STX
#3295 |
Drives: '15 STX
You can use the spare tire holding bolt on the rotors, it's the same size and pitch IIRC.
#3296 |
Drives: 2022 BRZ
all you need is a BFH
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
| The Following User Says Thank You to Simmons For This Useful Post: | DocWalt (05-11-2018) |
#3297 |
Drives: '22 WRB
For future reference when working on cars that don't have the hole in the hub face of the rotor, you can always put a big bolt through one of the holes for the caliper bracket, and thread it through a couple big washers and a nut in between the bracket and rotor. Bolt will push on the rotor when you thread it all the way in you can wrench it against the rotor. Tighten it up, loosen and rotate the rotor, tighten again. It'll pop.
#3298 |
Drives: Toyota frs86
Random question. Anybody try 265/35 on 18s. Re71r’s or 18s illegal?
#3299 |
Drives: '22 WRB
#3300 |
#3301 |
STX 188
Got no torque to tell them. lol
#3302 |
Drives: 2013 FRS
I tried out my 350/275 spring setup this weekend. The co-driver took first in class out of 10. The car gripped great and handled nice and predictably. Easier to drive than on 400/400 for sure in most features. I still haven't quite figured out how to drive it yet so I can't say it's great all around yet. But I like it. It definitely handles bumps better. I will say it does roll significantly more even with a Perrin front bar set on stiff, so transitions require a little more anticipation. Another benefit of the softer springs is that the low speed damper adjustments make huge differences. A total of 3 clicks of change (2 rebound and one compression) on the front took the car from balanced to extremely loose. Settings still are not perfect but it's nice to have that level of control. Just thought I'd post some feed back on my softer spring experiment. So far I like it.
#3303 |
Custom User Title
Are 17x9 a must or can you get away with 17x8.5 and still be competitive?
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#3304 | |
All you’re sacrificing is contact patch. Sure you’d can get away with 8.5” but it’s in your favor to upgrade Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
