Old 11-30-2017, 02:11 AM   #2997
e1_griego
e1_griego's Avatar
Drives: Many
Once my buddy makes one set I assume he'll be able to make more.
Like I said, will update once I have something to update with.
Mostly just annoyed lol.
ST is supposed to be the easy button!
e1_griego is online now   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
strat61caster (11-30-2017)
Old 12-01-2017, 02:19 PM   #2998
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Originally Posted by e1_griego View Post
I'm confident I know the answer to my question already, but what are the current STX lca options that are available?
Racer-X doesn't sell poly any more. And isn't really wanting to play ball on selling me replacement bushings.
Velox
RS-R
SPC/Dif bushings
SPL with steinjager poly
Is there a middle ground between $550-600 and the SPC/Dif bushing setup that I'm missing?
Whiteline lca are cheap and good
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 12-04-2017, 05:25 PM   #2999
ryan t
Drives: frs
question for those that have scaled their cars, what is your front/rear %? my rear end seems light at 43.5% or i may be wrong and thats normal?
ryan t is offline   Reply With Quote
Old 12-04-2017, 05:36 PM   #3000
cjd
cjd's Avatar
Drives: 2017 BRZ
Depending on your setup and fuel level, that's easily normal in my experience. All the cost effective weight reduction is in the back.
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (12-04-2017)
Old 12-04-2017, 08:53 PM   #3001
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
That looks normal. Running with less fuel, having a lighter exhaust, and removing the spare tire and tools from the trunk will shift the weight distribution to the front.
Factory is 55/45. 56.5/43.5 is close enough anyways.
G_Ride is offline   Reply With Quote
Old 12-04-2017, 10:16 PM   #3002
Icecreamtruk
Drives: Track preped NA FRS
55.9/44.1 for me at my last official weight check. Race fuel condition (half tank) and guted car on the rear only without passanger seat.
Old 12-05-2017, 08:59 AM   #3003
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
On the subject of balancing, what do you guys do for cross-weights? 50/50?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 12-05-2017, 09:20 AM   #3004
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
With coil-overs, you want ( and should be able to get) 50/50 cross-weights.
Copy/paste from my old 350Z STU build:
Corner balancing: I didn't even understand what corner balancing was until I borrowed my club's scales and spent a weekend in my garage with google and youtube:
My results, with me in the car and 1/2 tank of gas.
Corner balancing is apparently more like "leveling" a dinner table than "balancing" weight distribution. The weight at each corner of a car, on a level surface, is more of an indicator of the suspension's length/height at each corner than an "end" unto itself.
A car with poor corner balancing is similar to 4-legged dinner table that can rock back and forth when two opposing corners' legs are longer than one or both of the other two. But, whereas a table will rock back and forth over the long-legged axis, and alternately lift the two shorter leggs off the ground, making the issue obvious, the springs on a car will keep all four tires in contact with the ground and mask the issue.
The 4 individual scales, and the resulting weights, show how much force each tire is putting on the ground while at rest.
Less force (weight) on a cross-weight (DF+PR vs PF+DR) means one or both of the "table legs" are too short relative to the heavier cross weight. Or, conversely, the heavier cross-weight has a "leg" or "legs" that are too long.
Twinz is offline   Reply With Quote
The Following 3 Users Say Thank You to Twinz For This Useful Post:
DocWalt (12-05-2017), nico_rsx (12-05-2017), Silver Ignition (12-05-2017)
Old 12-22-2017, 10:17 AM   #3005
ryan t
Drives: frs
did we ever get an answer to is the full spec twin rear alignment kit STX legal with that toe adjuster?
Old 12-22-2017, 07:53 PM   #3006
strat61caster
strat61caster's Avatar
@M0nk3y wrote a letter that hasn't been responded to yet, next month's Fastrack hopefully.
My SPC links will be going in next week, I'll be measuring and comparing the bushing to stock.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
cjd (12-22-2017), Qadthane (12-22-2017), ryan t (12-22-2017)
Old 12-26-2017, 05:08 PM   #3007
M0nk3y
I'll try to see if I can get an update on that letter. I've received no email updates as of yet
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
strat61caster (12-26-2017)
Old 12-28-2017, 03:11 PM   #3008
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
There is no movement per say on it. It would/could not be legal for 2018.
2superblus is offline   Reply With Quote
Old 01-17-2018, 02:11 PM   #3009
strat61caster
SPC lateral link rod end looks legal to the naked eye, took some measurements and will be confirming the math later tonight, super glad I got it in though, alignments are so much easier with the two threaded links (combined with some new slip plates), they're staying in unless I head to nats and a fasttrack states they're illegal. However some of my difficulty may be due to damaged cam bolts/washers on the stock links, they're a bit tweaked and not as precise as I would hope.
The SPC feel much heavier than stock as well, I should be able to get the stockers on the scale before I post up the math.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
cjd (01-17-2018), justinco (01-17-2018)
Old 01-20-2018, 12:13 AM   #3010
JoeCFRS
Drives: 2013 Firestorm red FRS manual
Any other mid level coilovers besides the KW v3 and Tarmac 2s worth looking at?
Recently upgraded my 13 frs to a 17 brz. I ran fortune autos the last few years in STX, and while they were competitive locally and i did well on them, I'm looking for a new setup to be nationally competitive. MCS are out of the question because i just can't afford them.
Thanks for any help
JoeCFRS is offline   Reply With Quote
Search this Thread:
Advanced Search
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
