#2633 |
Drives: Many
My strano bar with shorter whiteline endlinks is silent.
I get a couple noises from the rear whiteline bar/endlinks, but I'm ditching the whiteline links for racer-x spherical one that aren't just perma-bound like the whiteline setup. |
| The Following 3 Users Say Thank You to e1_griego For This Useful Post: |
#2634 |
Drives: 2013 Raven FR-S
#2636 |
#2637 |
Drives: Many
#2638 |
Drives: 23 GT4RS
Just wondering what the "legality" of the new irp shifter is:
http://www.ft86club.com/forums/showthread.php?t=111626 The rulebook states "Any mechanical shift linkage may be used" so it should be all good, just wanted to check here to be sure. |
#2639 |
Drives: Fr-s
I don't think you can remove the shift/trans stabilizer.
I'd say not legal, unless you could leave that part in (which I doubt).
#2640 | |
Drives: '87 Corolla GTS, '13 FR-S 6MT
#2641 | |
Drives: 2017 BRZ
edit: Ok, it's clear not everything moves. It's not clear that it does anything other than hold the shifter, though. The difference is the stock shifter mounts to the transmission vs the car frame. I think. Last edited by cjd; 01-14-2017 at 07:43 PM. |
#2642 |
Drives: 2015 Scion FRS
Can any one tell me if wheel spacers ..(25mm) are legal in STX class?
I need them for perch rubbing issues |
#2643 | |
Drives: 2017 BRZ
That said, that's a lot of offset change. Something seems off here to me with your setup (it could be you're not trying to be competitive, but don't want to be illegal either... or something. I should stop guessing.) C |
| The Following User Says Thank You to cjd For This Useful Post: | Shark_Bait88 (01-16-2017) |
#2644 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#2645 |
Drives: 2017 BRZ
#2646 | |
You had the right idea. Im gonna stop guessing now |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
