#2353 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Echoing front bar love today. I put on the Hotchkis front bar on the low setting and it's a beast in slalom. The increased limitations of the car are always welcome, now it's time for the driver to exploit them....
Sent from my A0001 using Tapatalk |
#2354 |
Drives: '22 BRZ
Some fun stats from autocross yesterday: 1.2G steady state cornering, 1.32G peak cornering. 1.23G peak braking (sustained too!) and 0.66G peak acceleration. I'd say the RE-71Rs are pretty grippy!
I rode in a friend's CS prepped BRZ for the first time yesterday... He's a great driver (I'd say better than me anyway) and knowing that my car was 1.7 seconds faster is wild considering how fast his car felt, lol.
#2355 |
Drives: 2015 Series.Blue
Hi, I have been reading through these pages and found answers for 2013 but wanted to check if a couple things were current.
1. E85, still STX legal? 2. wet carbon hoods. Lots of hail damage around here recently. I assume any vented version would for sure be a no go. |
#2356 | |
Drives: Ultramarine FR-S
2. Can't use non stock hood. |
#2357 |
A.K.A. Starlord
HI GUISE!
So this is my second year autocrossing, and my first year in STX. Last year I autocrossed bone stock. This year I threw on KW V3 coilovers, camber plates, LCAs, and am running 245 RE71Rs on 17x9 wheels. It seems to be working, because I've taken 1st place in STX in both events I've done this year so far! At the autocross this weekend, my car was leaning so much through the slaloms that I was scraping my Gorilla flaps on the ground. I decided this was a good opportunity to make use of the adjust-ability of the KWs, as I had been too lazy to adjust them up to that point. So I dove under the car between runs and set the compression to full stiff at all four corners just to see what would happen. It made an ENORMOUS difference in body roll, but the car became very tail happy. So I let a bit more pressure out of the rear tires, and after that I was very happy with how the car handled. So, my question is: For autocross, is there a reason I wouldn't want to just make everything full stiff? The KW V3 isn't a "track-only" coilover, so it's rather soft. I would think I should just turn everything up all the way for autocross, where the car just gets violently tossed around, and then tweak the over/understeer with tire pressures. Is that a decent approach? Also, I never touched the rebound that day because I didn't have the key on me in grid. Should I max that out as well? |
#2358 |
It doesn't hurt to try and no matter what anyone says, experiencing something first hand beats free advice, and sometimes paid advice too.
Too stiff and a bumpy course may cause the car to become unsettled easily is really the only big problem with going too stiff. Also check the manual on the KW, some dampers do not want you running full soft or stiff like Koni, can't remember if that's true for KW or not. |
#2359 |
APEXHNTR
Drives: 10 Series FR-S #1867
It's really gonna be one of those personal things I think...I doubt there's a set number that works for everyone. It'll also depend on other mods, alignment settings, driving style etc...
I prefer my car to be on the softer side for autoX, I usually run my KWv3 3 or 4 clicks up from full soft on compression. I got a click or two stiffer on rebound to control body roll, which with a Perrin 22 and TRD 17 is negligible. At the last dry event I had the car setup as follows: FRONT C+3 R+5 30psi REAR C+3 R+4 32psi (number of clicks from full soft) I like the feel of this setup for me. I tried the first event with all settings at midway and I was really uncomfortable in the car, it just didn't feel right to me.
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
| The Following User Says Thank You to Silver Ignition For This Useful Post: | smg1138 (05-17-2016) |
#2360 | |
How low are you, how much clearance do your flaps have, and have you been corner balanced? |
#2361 |
Drives: 2013 Raven FR-S
Yeah, I can't imagine going full stiff in AutoX would be a great idea. Very few of the courses we run on are smooth enough to pull that off. I have Tarmac 2's and generally use RCE's recommended settings for AutoX. On street I usually set them pretty close to full soft.
#2362 |
Kind of depends on the course and surface, but going full stiff on compression is going to have all kinds of negative tradeoffs on most lots and courses.
What kind of swaybars are you running? How low are the flaps? Body roll isn't necessarily a bad thing. Most people running around 400lb springs in STX use fairly low compression. |
| The Following User Says Thank You to xwd For This Useful Post: | 2superblus (05-17-2016) |
#2363 | |
Drives: 13 BRZ WRB
#2364 | |||||
A.K.A. Starlord
I don't have any other modifications such as sway bars or anything. I'm not against body roll, but I wouldn't mind not hitting the flaps on the ground, and I honestly thought the car felt a bit more sharp, and less sloppy through the slalom when I pumped everything up to max. Quote:
![]() Quote:
Stock swaybars at the moment, though I'm thinking that might be my next modification. My V3s are probably the revised spring rate, which is closer to 280 lb or so, so I'm probably going to need to run higher compression settings. Ha! You know who I am? That's not good! Lol. I hear Milwaukee is much more competitive, so I'm trying to make it up there but work so far has been a bit roadblock, and this weekend will be no different, unfortunately. Maybe the next time? Really hope to make it to ONE of your events this year, at least. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | 2superblus (05-18-2016) |
#2365 | |
Drives: 2017 BRZ
On the other hand, it may just be that leaving your lights on caused the whole day to go out of whack... |
#2366 | |
A.K.A. Starlord
I definitely feel that I was faster with the car stiffened up. It was just TOO soft before and it made things a bit sloppy and harder to be precise with the car. I understand stiffer springs would be better, but they aren't in the plans - at least not at the moment. Otherwise I would have gotten the Tarmac 2s. I intentionally went with the KWs because this is still 99% a DD car, and I wanted it to be comfortable, so I'm just looking to make the best with the current spring rates. Not trying to go to Nationals or something, lol. I sure wouldn't mind trying a stiffer car out just to see the difference, though
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
