86WORX
Old 05-01-2016, 10:54 AM   #2325
mpross
mpross's Avatar
Drives: 2015 Scion FRS
See Blaine's post above, breaking axles may have been overblown as I haven't seen anyone with one recently. Keep an ear out for axle ticking, buy new axle nuts if you start to hear it tick (fixed my ticking) and keep the e-brake lubed so that noise isn't throwing you off either, they rarely go without warning.
As for 'willing to eat costs', for some it's a AAA tow truck, a $140 replacement axle and a greasy afternoon, for others it's a $500-$1000 trip to the dealership. If you're a casual autocrosser I wouldn't worry about it, if you're planning on 50-100x hard launches a year on 245 RE71R/BFGRS, might be worth sacrificing the looks if you can't prove the performance benefit to yourself.
Ultimately, this is racing, take everything with a grain of salt and prove it to yourself. Do whatever feels right, if I was your buddy I'd shrug and say 'keep it low, if you bust an axle you'll know why'
Maybe it was just a bad batch and they've all been broken now, all the ones left are rock solid. In any case, useful suspension stroke keeps me from lowering the car, not the broken axle potential.
That's reassuring. I'm definitely not slammed and didn't want to lower mine to the point where it was no longer functional from a performance standpoint. It's never rubbed on any corner so far, so suspension travel seems fine. I'll just be conscious of that possibility and if something does happen I would definitely be in the greasy afternoon, less expensive category.
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 05-01-2016, 02:58 PM   #2326
Silverspeed
Drives: 2014 FR-S
Well said. IMO this is something that the SCCA should allow to be upgraded from a durability perspective in the ST classes. If I do break one I'd like to be able to upgrade them so it doesn't happen again.
Silverspeed is offline   Reply With Quote
The Following User Says Thank You to Silverspeed For This Useful Post:
smg1138 (05-02-2016)
Old 05-02-2016, 05:23 AM   #2327
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I thought about writing a letter about the axels after I broke one two years ago. But then I didn't break another so I never did.
For me stronger axels isn't something that makes you faster.
Old 05-02-2016, 09:58 AM   #2328
cjd
cjd's Avatar
Drives: 2017 BRZ
It might need a lot more detail... Same or greater weight, for one. Does that just go for axles, or also driveshafts? How about rods and pistons? It's a slippery slope.
Old 05-02-2016, 11:48 AM   #2329
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Unfortunately there's an idea that some cars could suddenly be a lot faster with some reliability mods. Heck, the radiator and oil cooler allowance took quite a while to be accepted. Some cars would lose power after a run or two due to heatsoak and they were depending on that loss in performance to keep classes balanced, which is a touch silly.
Old 05-02-2016, 01:01 PM   #2330
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
ROLL CENTER
Okay guys...got my 14mm, 17mm, 19mm and 22mm wrenches, tape measure and a Hunter Alignment rack.
Right now my front is VERY low by your numbers at 24.75".
Has anyone input the geometry into a calculator to determine the IDEAL ride height for a proper roll center?
Tonight I plan on setting my front at 25.25" and rear at 25.5". Next autocross is 5/22 so we'll see how she does.
Also while it's on the rack I think maybe I'll take measurements to input into a roll center calculator and try and dial in the PERFECT ride height.
Any comments or concerns?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
Old 05-02-2016, 01:17 PM   #2331
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
My only thought was that corner balance can't be perfect while still having perfectly balanced ride heights all around.
GeorgeJFrick is offline   Reply With Quote
Old 05-02-2016, 01:48 PM   #2332
renfield90
The Stig's German cousin
This thread will help you out: http://www.ft86club.com/forums/showthread.php?t=26661
Includes front and rear roll centers at OEM height. I haven't dug into the whole thread yet (many pages) but on the first page at least, they don't include how they derived those numbers. But they do come from a Penske engineer so I would consider them valid.
According to him, front roll center drops below the ground with more than 1" drop from OEM. This is gonna make me do some thinking...the STX FRS I drove was absolutely slammed but drove really well anyway IMO.
The Following User Says Thank You to renfield90 For This Useful Post:
Silver Ignition (05-03-2016)
Old 05-02-2016, 03:44 PM   #2333
slyphen
slyphen's Avatar
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
asking for a friend. are 2013 STI qualified for STX?
slyphen is offline   Reply With Quote
Old 05-02-2016, 04:02 PM   #2334
gtslow
Drives: 2015 Halo FR-S
WRX STI falls under STU
gtslow is offline   Reply With Quote
The Following User Says Thank You to gtslow For This Useful Post:
slyphen (05-02-2016)
Old 05-02-2016, 04:03 PM   #2335
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
No, they're in STU (assuming you mean the WRX STI and not the Series Blue)
The Following User Says Thank You to DocWalt For This Useful Post:
Old 05-02-2016, 04:34 PM   #2336
strat61caster
strat61caster's Avatar
See the rulebook, specifically Appendix A:
http://www.scca.com/pages/solo-cars-and-rules
ineedyourdiddly
Old 05-03-2016, 06:15 AM   #2337
BlaineWasHere
Grip>Drift
Drives: FRS
It is a slippery slope. I was going to specify actually only axels.
The thing is it's difficult to police. Would anyone even know if I had upgraded axels right now?
The main reason I bailed is I haven't broken another axel in almost 100k miles and when I thought about it I think it's best to keep the weak link the axel. If I upgrade them I don't wanna go around blowing up diffs.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
cjd (05-03-2016)
Old 05-03-2016, 08:56 AM   #2338
Silver Ignition
APEXHNTR
So ride height is now at 25.25" front, 25.5" rear ground-to-fender...4.75" front, 5" rear ground-to-pinchweld.
Car feels much looser, a lot more body roll (dampers are set to full soft for the rain aX on sunday) so I'm thinking it's time to bump up rebound and let the dampers do their job.
Even with the extra body roll I was able to maintain much higher speeds on the twisty road I take to and from work...one corner that I usually take between 52-54mph I took at 74mph! Not sure if placebo or if maybe it just instills more confidence but I cant wait till the 22nd for the next local aX!
#1867 of 2500
Search this Thread:
Advanced Search
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
