#71 |
Fiannly getting around to it today!
#72 |
ハチロク
Drives: 2015 FR-S Ultramarine Blue
Adding my 2¢
Hi,
I had a hard time getting off the front badge. I'm sharing in case it might help anyone. It was a sunny, warm day so I thought that would help soften the adhesive. You definitely want Goo Gone to loosen the adhesive. I wasn't making any progress until I used that. I got a start with dental floss, then used a plastic trim removal tool to wedge the side up. The piece came off pretty easily, but left all of the adhesive on the car. It was a lot of work to remove. What seemed to work best was to soak some Goo Gone on the adhesive, use some heat from a heat gun, wipe the Goo Gone off to get some friction with the adhesive, then rub across to remove it with my thumb. This took a lot of time since there was so much adhesive left. My right thumb seemed to get the best resistance so I mostly used it. I ended up with a big blister on it. Goo Gone and rubbing was the way to remove the last bits of adhesive. It did finally clean up nicely. I'm hoping the rear badge is a lot easier when I try it this afternoon. Cheers, LD |
| The Following User Says Thank You to Caspian For This Useful Post: | Ammunition (07-10-2015) |
#73 |
Drives: 10 Series
Thanks to FRSupra for starting this thread! Those Toyota part numbers are huge! Definitely a proven removal method I removed the FR-S badge using the same method.
I have an extra hole under my rear scion badge besides the 2 pin holes for wiring to the illuminating badge (10 series). Questions: -Anyone have any suggestions for plugging or hiding the 3rd hole? Maybe a solid non see through badge? was trying to go uncolored too -Anyone have any suggestions to illuminate a Toyota badge or know of one? |
#74 |
Bringing Hachiroku Back
Drives: 2013 Firestorm FR-S
This sucks.. now that Im finally getting around to swap out the emblems the prices jack up fml. Would really appreciate if anyone could help me out with where could I get them at a reasonable price. 30+ for a plastic emblem is ridiculous.
Sent from my SM-N910P using Tapatalk
#76 |
Drives: 2015 Fire
Guys so do the USDM badges come with double sided tape already?
#77 | |
Sent from my SM-G925P using Tapatalk
#78 |
Drives: FRS monogram
$56CDN for the Avalon badge.. Tried eBay
They either don't ship to Canada or cost another $25 for shipping Boooooo Don't know what to do with my life now |
#79 | |
Drives: 2013 whiteout frs
What is the best way to black out these badges? Plasti dip or paint? Or does anyone know where I could purchase a pair of T badges already blacked out? |
#80 |
Spline Reticulator
Drives: 2013 FR-S Whiteout
I've seen a few already blacked out but overpriced - you'd have to search around. I'd go with Plasti. You can just mask around the badge, spray a few coats, then peel off everything that is not badge. And if you have not put them on the car yet, it's even easier. If you screw up, you just peel it all off, wash the surface to be safe, dry, try again. With paint, you get one shot - they can get messed up even painting them before attaching. (drips, runs, etc).
Johnny was a chemist's son, but Johnny is no more. What he thought was H2O was H2SO4. ![]() |
| The Following User Says Thank You to Semprini For This Useful Post: | bizintine (06-01-2015) |
#81 | |
#82 | |
Spline Reticulator
). They also sell a gloss spray you can put on top of the colored plasti to smooth it out if you don't want the rough look. Rust-oleum also makes an almost identical product but I'm not sure about layering that.
#83 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Or you could use a GT86 Emblem
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| The Following User Says Thank You to Aztec For This Useful Post: | haimichaeltran (06-05-2016) |
#84 |
That's actually pretty cool Aztec. But I'm diggin the OG toyota T
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Facebook "Scion First 86" group for First86'ers and other early FR-S owners... | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-20-2012 01:43 AM |
| PENSKE TOYOTA SCION "FRS PRWVIEW PARTY, CAR MEET" | Moto-P | Southern California | 21 | 05-17-2012 11:43 AM |
