#323 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | brzaapi (01-20-2015) |
#324 |
Drives: 2013 GBS BRZ Limited
I have have been wanting to make a switch that tells the car that it is warmed up just for the pedal dance.
I even looked up the pinouts on the ECU, but havent dug in any further. All it needs to do is open the circuit to the cooolant temp sensor, and switch in a fixed resistor. One you complete the pedal dance, you switch it back to reading real engine temp. It would probably mess with the ECU running any special "warmup" maps, but it should be inconsequential. |
#325 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Well if its not the thermostat, and not the tune. I am just perplexed. I really don't think it is user error, but maybe. If anyone else has any ideas, please let me know.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#326 | |
The Stig's German cousin
#327 | |
The only difference is going from warm to not warm instantaneously. I suppose that it's possible to upset the state machine, but I would hope the software is more robust than that. |
#328 | |
#329 | |
Should not affect any other operation. The system should operate normally under a failed temp sensor, so one reading strangely (jumping abrubptly) should not break it. Last edited by stugray; 01-20-2015 at 06:09 PM. |
#330 | |
#331 |
Try doing it "slower". Some people rush it, but you can really do it slowly. Make sure the "BRAKE" light goes off between e-brake pulls.
#332 | |
CAR-AHOLIC
I will definitely try doing a couple slower run throughs. Thank you sir.
#333 | |
CAR-AHOLIC
Alright. I still can not get the pedal dance to disable the nannies. I have an event this Sunday, so I wasted almost an hour trying it over and over. Finally something occurred to me. I did not install TPMS sensors in my latest set of wheels. I hate tpms, so I didn't bother. But when the car is going through the start up sequence, the tpms is sensor is blinking, and then goes solid since it cant find tire pressure. That is the only thing that happens in my car, that probably doesn't happen in many others. Do you think that sensor/idiot light staying on could cause the car to not allow the Non-Nanny/pedal dance mode. Like to hear your thoughts.
#334 | |
Drives: 2015 Raven FRS
I don't have TPMS on my track wheels and I can still do the pedal dance. |
#335 |
CAR-AHOLIC
Damn. I thought I found the reason. I may just post a video of me doing the damn thing. But I cant believe I am screwing the sequence up.
#336 | |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 12:24 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 09:55 AM |
