#309 | |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
| The Following User Says Thank You to Kido1986 For This Useful Post: | brzaapi (01-19-2015) |
#310 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Yes. I turn the car off. Then restart and do the process well within 30secs. I have tried it with radio on,off I have tried with foot on clutch, and off In short I have tried it in numerous combinations. I was able to do it on my 12 BRZ. But I have never been able to do it on my 15. Now that being said. I didn't try till after I had a flash and thermostat installed. I don't think the problem is the way I do the pedal dance. But obviously if you think I am doing something wrong please point it out. Thanks to all for help.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#311 | |
fabulous
| The Following User Says Thank You to Ultramaroon For This Useful Post: | brzaapi (01-19-2015) |
#312 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | brzaapi (01-19-2015), Ultramaroon (01-19-2015) |
#313 | |
CAR-AHOLIC
Yes sir. I have a UEL header and 91/E85 tune from Shiv at Vishnu/Openflash. Please let me know your thoughts, but obviously I need to go ask Shiv about this as well since he was the tuner.
#315 |
Shiv should know the circumstances under which the Pedal Dance doesn't work, but at the moment, if the other conditions like ECT are met, then it sounds like an issue with your particular tune.
#316 | |
CAR-AHOLIC
I agree. I have actually never ran into a problem with any of Shivs tunes, whether it was on a BRZ or Miata.
#317 | |
CAR-AHOLIC
Well, I am waiting to hear from Shiv. Do you think it could be a thermostat thing at all? My temp definitely runs cooler.
#318 |
Drives: '13 BRZ / '11 Outback / '06 Tundra
I've got an openflash and can verify that the dance works fine with 91 and 93 octane Stage 2 UEL tunes ('13 BRZ). Can't comment on the E85 tune though. I like where the thermostat idea is going. If it's 5 degrees cool then the dance will never work.
#319 | |
The Stig's German cousin
From experience, it doesn't take much cooling to get under the threshold. I could go autocross my car hard in 90+ degree weather, shut the car off in grid and in two minutes when I go to start it again, it's cooled off too much. |
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | CSG Mike (01-20-2015), Ultramaroon (01-20-2015) |
#320 | |
CAR-AHOLIC
No I don't. Not for this car anyway. But with the OFT, it shouldn't be hard to get something and take a look at values. In fact I think the OFT may actually show the temps on the screen. But to be honest I have not dived into the OFT too much. So, for the pedal dance to work, am I right in saying that you want your water temp to be above 190f before the car will allow it. Thanks everyone. Next AX is Feb 8th...if the weather doesn't kill it.
#321 |
Drives: 2013 GBS BRZ Limited
A ELM327 from ebay for $10 and Torque will allow you to see your temps.
And a tune should not affect the pedal dance as the Engine ECU does not enable/disable TC/VSC. Different ECU. |
#322 | |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 12:24 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 09:55 AM |
