#253 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | funwheeldrive (03-08-2017) |
#254 |
noob and expert
Drives: None :(
Ok starting to get confused is ebd the electronic system that splits the bias front and rear or the system that brakes individual wheels?
For me, there is no glide in pulse and glide :p |
#255 |
EBD == Electronic Brake force Distribution; ie. electronic and computer controlled bias. I believe I've read it can actually distribute to all four wheels independently and is part of the traction control and ABS systems on our car.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | CSG Mike (09-02-2014) |
#256 | |
#257 |
I usually don't have problems with the e-diff at all on stock suspension; it only happens on the stuff with high spring rates (and minimal droop)
#258 |
StreetKart
Drives: 2014 Scion FR-S Monogram
so what causes the hopping on the inside? bone stock suspension at the moment. this was on a 50ish mph hard right with banking. on this road
![]() I assumed it was cradle bushings being pushed to their limit and then the tire breaking free and basically getting axle wrap/wheel hop due to a sloppy stock bushing
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#259 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#260 | |
#261 |
Drives: FR-S Firestorm 6MT
I tried the Pedal Dance for the first time this weekend.
After 2 years of track days with this car, I would only disable the nannies via the 5-sec press. Now I find the rear of the car much more stable on hard braking hairpins or transitions. Will keep using it on the track as I see no downsides (other than the process). |
| The Following User Says Thank You to Slick For This Useful Post: | CSG Mike (09-03-2014) |
#262 | |
#263 | |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
This was asked in another thread:
Well, I didn't hold up my end of the bargain. I never bugged you about it. What are the odds that you remembered and had a chance to test this? |
#264 | |
#265 |
Some say.....
#266 |
So, since you're already not getting any braking effect due to the ice mode, you can jump right off and ease right back on in one continuous movement, and if the condition causing ice mode in the first place is no longer present, you now have braking force. This is good to know. Thanks!
| The Following User Says Thank You to dradernh For This Useful Post: | CSG Mike (09-04-2014) |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 12:24 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 09:55 AM |
