#239 |
Drives: 2013 Firestorm 6MT FR-S
idk if anyone has seen this because frankly i didn't look through all the posts on this thread, but i found this on youtube for those that wanted a video…
[ame="http://https://www.youtube.com/watch?v=CWXv7UNA7hg"]http://https://www.youtube.com/watch?v=CWXv7UNA7hg[/ame] |
#240 |
it looks like pedal dance is rpm sensitive, I had my tuner raise my idle rpm to 950 (got a light weight flywheel and it idles better at 950) and now pedal dance doesn't work
#241 |
Drives: Nissan GT-R
Thanks for all the pedal dance info
This is very helpful for those of us looking to track/autox the BRZ... thanks to all the contributors!
| The Following User Says Thank You to 200HP For This Useful Post: | CSG Mike (09-02-2014) |
#242 |
Drives: 2022 BRZ Limited
Pedal dance worked for me yesterday with no problem.. I ended improving my best time by 1 second at Ridge Motorsports Park yesterday but I am not sure if it was the pedal dance or the ST43s or maybe combination of both
| The Following 3 Users Say Thank You to glamcem For This Useful Post: |
#243 |
StreetKart
Drives: 2014 Scion FR-S Monogram
I'm wondering if this will fix my issue on hairpins in the mountains... at WOT on tight turns in 2nd gear the traction light will come on. I can feel it hoping and binding but the car bogs pretty hard when this happens and the last time i did this i thought i was going to have my buddies C6Z crawl straight up my tail pipe. I'm going to test this soon.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
| The Following User Says Thank You to Roadcone For This Useful Post: | ATL BRZ (09-02-2014) |
#244 |
noob and expert
Drives: None :(
Hey this isn't exactly the right place to ask this question but I figured since it's a brake thread and u guys were mentioning ebd here I might as well ask here.... Apparently 08+ sti Brembo brakes for this car so long as u drill new holes in the rotors. I was told that sti brakes were heavily front biased vs the stock frs brakes. Also, improving brakes isn't as simple as just spending 7k on big brakes for front and rear. In fact, sometimes it worsen performance but prolongs consistency which isn't so important on a street car or on a car that isn't heavily tracked. Would there be any benefit to upgrading to those brakes or another bbk assuming you already have the tire problem taken care of? (since tires stop the car) this car is also light to it doesn't take a tremendous amount of effort to stop it. Say the car is a dd with several track days every year (10 for example) is there any upgrades available for master cylinders? How would a bbk affect performance with ebd and abs on and with the pedal dance?
For me, there is no glide in pulse and glide :p |
#245 |
noob and expert
Drives: None :(
I was also told the sti components were heavier which adds to rotational mass. Correct me if I'm wrong.
#246 | |
#247 | |
Chances are, if you gotta ask about it, you don't need a larger master. |
#248 |
StreetKart
The stock LSD on this thing seems pretty tight. i get some pretty loud tire chatter driving around normally.
| The Following User Says Thank You to Roadcone For This Useful Post: | CSG Mike (09-02-2014) |
#249 | |
The computer, without the pedal dance, also functions as an e-diff, so it's braking the wheel that is spinning to help the torsen function, which is the blinking traction light you see. If you spin the inner wheel without the pedal dance, then the solution is the LSD. If the computer is being overly conservative (which is can be at times), then the pedal dance is the solution. |
#250 | |
i'm sorry, what?
Drives: Canada
with the pedal dance (ebd disabled), when the torsen begins to be defeated (inner wheel spins), it (ebd) will not interfere and your car will enter into a state of having an"open diff" this, however, in your opinion, is a better state than having ebd interfere y/n
#251 | |
Simple answer is yes, I'd rather lose EBD and not have the e-diff, since neither are things I want. It's the same reason I find the C7 vette unpredictable with the e-diff. |
#252 | |
i'm sorry, what?
Drives: Canada
well, I do get the blinking traction light on an overly dusty and "tight" autocross. 180* hairpins will almost universally cause the light to go on and after reading the previous few posts I've started to wonder if I too feel like the car "bogs", just a little, in those situations. I really should try to disable it... lol , with the proximity of light posts and curbs the possibility of icemode is a little freaky to me, much scarier than just sliding off into the grass on a track.
| The Following User Says Thank You to 7thgear For This Useful Post: | BRZ21 (09-02-2014) |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 12:24 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 09:55 AM |
