#29 |
Drives: 2013 WRB BRZ
If you can check Costco on the RE-11A - I got the 245/40/17 RE-11A for @165.
RE-11A on tirerack show for comparison: 215/45/17 - @141 225/45/17 - @163 245/40/17 - @174 I would expect possibly better prices per tire at Costco - had to special order the tires fyi and took about 4 days to ship to the local Costco near me. But you could also get a Firestone shop to pricematch Costco as well. |
#30 | |
Drives: 2013 Subota, 2010 911
The highway isn't F1 or Nascar, there wouldn't have been any investigation... just "speed was a factor" (not that I've been speeding, just work and back). However, the tires are feeling much better now... great tires. Just make sure to check your pressures when you leave the shop. Last edited by subota; 08-09-2013 at 07:18 PM. Reason: clarification |
| The Following User Says Thank You to subota For This Useful Post: | Hanakuso (08-09-2013) |
#31 | |
#32 |
I just went with the stock tire size... without looking it up I think it's 215/45-17?? I know they have 255's... I saw some tire 'review' that showed that the wider tire didn't improve performance and I'm not tracking or crossing so I decided that the stock size in an improved compound/tread would be enough for me.
#33 | |
people wouldn't. I'm not sure how much risk of a tire failure was posed but it certainly did make the car dart around.I haven't called them back but I think I will just to let them know to be careful with that. |
#34 | |
#35 |
Drives: Some rust bucket
All the extreme summer tires (RS3, DII, RE11A, etc) have wider tire shoulders compared to the OEM Primacy tires. So yes, they're wider overall even though they're all 215 tires.
#36 |
Tire pressure is very important to get the most out of your tires when driving at the limit. I typically run 35 psi front and 32 psi rear hot when autocrossing. This means they're probably at 32 and 29 cold. Under normal driving conditions, I generally run 40 psi cold for better MPG. They typically get to about 45 psi when hot. Since I'm not pushing the car under normal conditions, maximum grip isn't important to me. On my Civic, I run 60 psi cold, lol.
#37 |
Yeah I know at the least DII run wider but the S04 is a "max" summer tire so i'm not too sure how wide it is.
#38 |
I don't think I have any idea what the width is other than the '215' designation... so... I took a tape measure out there. The contact patch seems to be close to 8" and the total width is about 9". That was measured as closely as possible for a tape measure. Have a good laugh if that is totally meaningless!
#39 |
Drives: 2013 WRB Subaru BRZ 6MT
Does anyone have an update on the Bridgestone RE-11As?
#40 |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Been available for a while now. I used a 245/40/17 on 7.5" wide wheel. Used them during a summer, and a full season of autox. Great grip and decent wear characteristics. I ran 1.5 degrees camber front, rotated them fairly often and they wore perfectly even right down to the end. Around 10000km of street driving and 100 autoX runs. FWIW I ended up Atlantic Canadian overall champ in my rookie year. I ran in STX.
#41 |
Drives: 13 BRZ WRB
They are great street tires but are roughly 2.5 seconds off the pace on a 30 second course.
#42 |
Just a dude
Drives: Scion FR-S 2013
How are these for noise levels and overall comfort? I hate tires that are loud on highway or that say hello when driving over a small pebble.
| Did your FR-S come with Michelin or Bridgestone tires? | tomato86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 70 | 11-05-2013 11:20 AM |
| FS: Bridgestone Potenza RE01 265/35/18 235/40/18 | Migs. | Wheels and Tires | 10 | 08-01-2013 11:42 AM |
| FS: OEM Bridgestone Turanza Tires | FRS2000 | Wheels and Tires | 1 | 12-10-2012 11:33 PM |
| Wheel Directory: Bridgestone BEO ar.S-03 18x8.0 +49 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-05-2012 04:51 PM |
| NEW Bridgestone R10 Race DOT tire | RRnold | Other Vehicles & General Automotive Discussions | 2 | 06-17-2011 06:58 PM |
