86WORX
Old 12-30-2012, 06:55 PM   #15
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
99.9% chance it's just fine.
Old 12-30-2012, 07:02 PM   #16
ziggz501
ziggz501's Avatar
Guarantee you it's fine. Anyone that has to drive on a military base hits a decent speed bump at least twice a day. Keep in mind that every car is designed to be able to take some amount of punishment. Unless you spent over 100k on your car or modified the suspension, then it should be able to handle a few bumps in the road
ziggz501 is offline   Reply With Quote
Old 12-30-2012, 07:52 PM   #17
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
its normal.... Don't worry about it.... :-)
RL_BRZ is offline   Reply With Quote
Old 12-30-2012, 09:33 PM   #18
GREATNEESSS
I notice this all the time especially on the days when i drive home and like to give it a little more throttle through the open roads
GREATNEESSS is offline   Reply With Quote
Old 12-30-2012, 10:39 PM   #19
FRSupra
FRSupra's Avatar
It probably has happened before and you didn't notice it because your attention wasn't there. Now, since you're concerned, your buggin like sherlock.
The sound is normal and extra noticeable on the fr-s.
FRSupra is offline   Reply With Quote
Old 12-30-2012, 10:43 PM   #20
zenki_levin
Road Warrior
zenki_levin's Avatar
Drives: AE86 Levin
My ae86 makes the same noises after a long drive, sounds like a popcorn machine. Nothing to worry about.
zenki_levin is offline   Reply With Quote
Old 12-31-2012, 12:05 PM   #21
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
The noises are nothing. However, I would probably try to get the suspension, steering, and wheel assembly checked out.
I did a similar thing in a Stealth R/T Twin Turbo and it seemed fine -- until the brake seized up on that side and we found out the wheel / brake / suspension apparatus had been catastrophically damaged. Oh and it was very dangerous when it happened. The brake was literally red hot when I finally got the car stopped mainly using engine braking and e-brake. Be cautious.
Nepenthe is offline   Reply With Quote
Old 01-16-2013, 10:34 AM   #22
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
@Zach is having this same problem, I think. He stopped by the other day with a strange creaking noise from his front right area... we swapped the strut to see if that was the problem, but it wasn't. Seemed like it might be the steering rack. He was going to take it to the dealer next. Maybe we'll get an answer from him soon.
Sex-deprived male fruit flies seek solace in alcohol, bump into walls and pass out 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 8 06-11-2016 11:45 AM
Vendor post/bump limit JoeBoxer Site Announcements / Questions / Issues 8 12-24-2012 03:27 AM
The CRASH n BUMP thread!! MattQ-WP Issues | Warranty | Recalls / TSB 11 11-13-2012 08:05 PM
Crawfor brz damage? PowderfaceTr. Cosmetic Modification (Interior/Exterior/Lighting) 6 10-13-2012 10:29 AM
Minor paint damage Double4Free Great Lakes 8 07-23-2012 08:35 PM
