Old 01-31-2013, 11:49 PM   #43
karne
Drives: frs
+1 on stock shock/struts clearance
karne is offline   Reply With Quote
Old 02-04-2013, 09:30 PM   #44
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Just saw this got updated. It's awesome! My only note would be that camber settings seem to be inverted. Negative camber should angle the top of the wheel towards the car.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
itdansharpe (02-05-2013)
Old 02-04-2013, 09:56 PM   #45
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
awesome work!
kask2_6.0 is offline   Reply With Quote
Old 02-04-2013, 09:59 PM   #46
coyote
coyote's Avatar
Drives: Slowly
You're correct.
Also, inputting camber only changes the picture, not the DTF* (distance to flush).
* DTF is a DarrenDriven recognised measurement.
coyote is offline   Reply With Quote
Old 02-05-2013, 02:40 PM   #47
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Everything seems to be working properly but I believe your initial offset is off. At stock ride height with stock wheels (17x7 +48) the front should be 23mm from flush and the rear should be 30mm from flush. Or at least according to this anyways:http://www.ft86club.com/forums/showthread.php?t=7535
Old 02-05-2013, 02:50 PM   #48
itdansharpe
itdansharpe's Avatar
Excellent. Thanks. I did quickly Google this and may have mixed up the diagram I was reversing this off. I have inverted this.
I won't be adding in offset from flush WITH camber, as I can't see the benefit for the amount of work involved. I would rather devote time to strut clearance.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 02-05-2013, 03:03 PM   #49
raul
Lap time enthusiast
raul's Avatar
Very good call. Best of luck with that!
Old 02-05-2013, 03:16 PM   #50
djdnz
1337
Drives: 2013 BRZ WRB S/C
Very cool this will be so useful, thank you for your time spent developing it. How did you come up with the movement of the fender relative to the wheel while lowering?
djdnz is offline   Reply With Quote
Old 02-05-2013, 03:20 PM   #51
itdansharpe
Based solely on the calculations I've seen on this site, particularly this:
WHEN LOWERED 1" YOU WILL NEED TO REDUCE THE FRONT OFFSET
BY 2MM AND THE REAR OFFSET BY 5MM FOR PERFECT FLUSHNESS
Old 02-05-2013, 05:33 PM   #52
Skurj
Drives: SOLD...
Looking great!
Now.. anyway you can highlight what the factory spec camber is?
I don't know what those numbers should be.
The clearance from flush looks off... an 18x9.5 +38 from photos of cars with them fitted looks like it pokes a little, in your tool they look to still be inside the fender (at 0 camber)
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 02-06-2013, 01:51 PM   #53
RAYSSPL
Drives: bicycle
this should be sticky'd
RAYSSPL is offline   Reply With Quote
The Following User Says Thank You to RAYSSPL For This Useful Post:
Pete (02-06-2013)
Old 02-06-2013, 01:59 PM   #54
OrbitalEllipses
Drives: Attitude
Neat, but without wheel width this tool is very incomplete in showing you changes in fitment as width changes fitment the most drastically.
The latest version fixes all of these complaints and is infinitely more useful.
Old 02-06-2013, 02:43 PM   #55
sidnacious
sidnacious's Avatar
Drives: Argento FR-S
OMG thank you for the awesome update!
sidnacious is offline   Reply With Quote
Old 02-06-2013, 02:50 PM   #56
Pete
Pete's Avatar
Drives: 22 BRZ
Wow, that is awesome! Great job and thanks for your time & effort.
Pete is offline   Reply With Quote
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 163 04-06-2023 01:55 AM
Auto Fitment Calculator itdansharpe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-28-2012 02:09 PM
FR-S Speed/RPM Calculator FR-S #2637 Engine, Exhaust, Transmission 8 09-19-2012 12:41 PM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 12:31 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
