86WORX
go_a_way1
Old 03-06-2014, 01:48 PM   #1527
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
so much rubbing in the front. couldnt turn my wheels at all with the 18x9.5s up there so i put my stocks on, and still rubbing in the back of the liner (right under the tip of the fender vent) anyone have suggestions?
are you all running liners still or are they removed?
also, after a quick drive around the block im noticing some knocking in the rear. does anyone have any ideas? Im going to make sure everything is tight again... but idk. a friend mentioned it could be the preload? i dropped it as low as possible without being able to move the spring up and down... could that still be my issue?
im on BC extreme lows btw...
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
The Following User Says Thank You to Kuzuri For This Useful Post:
John.Hong (03-06-2014)
Old 03-06-2014, 02:12 PM   #1528
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
grind the tabs in the rear and remove your fender liners. you should also try adding camber from the top of the strut tower for some extra clearance. it looks like your running some meaty tires also
IG: nabb335
nab335 is offline   Reply With Quote
The Following User Says Thank You to nab335 For This Useful Post:
Kuzuri (03-06-2014)
Old 03-06-2014, 05:35 PM   #1529
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
not much has changed. had a tire debead last week, then remounted it, and ordered some new rear tires..
moomoopanda is offline   Reply With Quote
The Following 2 Users Say Thank You to moomoopanda For This Useful Post:
FreedE (03-06-2014), John.Hong (03-06-2014)
Old 03-06-2014, 05:55 PM   #1530
John.Hong
John.Hong's Avatar
Drives: 2013 Ultramarine Frs
Looks really good! I get the same knocking noise on small little bumps on the road or when going slowly. I've heard its endlinks touching frame or something. Or preload but I want to find out too. The front kind of does it but barely. The rears tho, asdjsakjdhadsflahsdk
John.Hong is offline   Reply With Quote
Old 03-06-2014, 06:15 PM   #1531
moomoopanda
Drives: Argento FRS
I think its the endlinks, I removed my rear sway bar and I'm pretty sure the clunking is gone...
Old 03-06-2014, 07:06 PM   #1532
Crazy Drew
Drives: Smells like tires when I drive
Would shorter end links fix the problem? Just curious because I have wheels and coilovers on the way. I could order up some rod ends to make my own end links to prevent them from hitting. I'd rather not remove my rear sway though, it'll make the car push hard and I still drive somewhat spirited.
Crazy Drew is offline   Reply With Quote
Old 03-06-2014, 09:57 PM   #1533
John.Hong
John.Hong's Avatar
Why'd you remove your rear swaybar?
Old 03-06-2014, 11:17 PM   #1534
SnapOv3st3r
Drives: 400whp Scion tC
Ever just thought about lowering the car to a respectable ride height?
SnapOv3st3r is offline   Reply With Quote
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
SkAsphalt (03-08-2014)
Old 03-06-2014, 11:27 PM   #1535
Kuzuri
__(X)__
Kuzuri's Avatar
What tabs? and removing the liners is pretty much the conclusion ive come to. haha. how dirty does your engine bay get now? Do you think maybe itd be possible to somewhat cover up the spaces that open up into the bay?
I added a little more camber up front but I can move the allen screw over one more space and max it out if i need to. I put the stocks on just so I could get it on the road and drive it around the block.
tires are meaty, right now. im running 245/40s from when i was only on s techs. I will be getting 225/40s soon and running spacers in the rear. (i have no rubbing issues in the rear right now btw. but thank you! i appreciate the help! and sorry for all the questions
Old 03-07-2014, 08:38 AM   #1536
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
I miss the accuair style fitment
This is the only car with respectable ride height lol
Follow me on IG: @rougarou86
boucher is offline   Reply With Quote
Old 03-07-2014, 09:21 AM   #1537
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
19x10 +50 rear and 19x8.5 +45 front Vossen CVT. Not aggressively lowered by any means, it is my DD. Eibach sportline springs installed yesterday. So far no rubbing issues.
Before springsName:  uploadfromtaptalk1394198472950.jpg
After springsName:  uploadfromtaptalk1394198504195.jpg
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 03-07-2014, 02:56 PM   #1538
John.Hong
John.Hong's Avatar
I'm on BC and i maxed out the front with 18x9.5 +35 up front. I'm "functional" with 255 so I'm not balls on the ground but theres tire tuck. No rubbing issue and my liner is full intact. But spacers in the rear with 225 is a good idea. otherwise it looks really weird lol.
Old 03-07-2014, 04:54 PM   #1539
boucher
Leaux Down Krewe
boucher's Avatar
Fancy, you shouldn't need to remove your fender liners. I'm running 18x9.5+30 with 215/35s and have no problems with clearance. Swapping to the 225s will help you tons.
Old 03-07-2014, 06:57 PM   #1540
Kuzuri
__(X)__
Kuzuri's Avatar
Im on the stocks right now and my fender liner is sitting on my tire and also hitting in the back... i cant imagine that 18x9.5s with 225s on them will clear if the stocks dont?
dontlike?dontlookmoveon
Search this Thread:
Advanced Search
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1742 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
