#29 | |
Newbie Car Enthusiast
Drives: Asphalt 6MT FR-S
#30 |
Drives: 2013 Ultramarine FR-S
#31 |
Drives: 2013 Scion FR-S-white out
Ya bro, unbolt your back seats and you'll be able to get your missing pieces. Problem solved
#32 | |
Still not quite sure how tho. I'm a dumbass at diys.. |
#33 | |
#34 |
Drives: 2012 honda civic ex
#35 | |
Drives: 2013 Subaru BRZ
![]() I thought that thread showed how to remove that, didn't look through it before posting the link. Once you do what he shows in that thread through step 2, you'll want to remove some of the door molding around the large panel and the piece of plastic on the bottom of your door frame, then that big panel will come out by just popping out a bunch of clips. There is probably another thread with more details, search around in the audio forum for instructions on how to replace the rear speakers. You should find some help. Good luck and hope you find the rivets. |
#36 | |
#37 |
#38 |
Drives: Whiteout FR-S
In my opinion, quit poking around before you do more damage. You lost a rivet? Live with it. Unless it makes an obtuse amount of noise or causes some sort of lack of functionality, quit while you're ahead.
Also, look at my member journal and check out my tail lights. Took about 30 minutes and required no tools at all besides a bit of masking tape and plastic lining
![]() 2013 Whiteout 6MT |
#39 |
Drives: 2013 FR-S Whiteout 6MT
Try a big shop vac and see if you can vacuum it out of the nook or cranny that its hiding in. If you haven't moved the car around, it probably just out of sight and the vac may pull it out.
Happy hunting...
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 04:27 PM |
| WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk | R0ME0 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 01-07-2014 10:36 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Exterior Parts (Aero, Lighting, Etc.) | 1 | 12-30-2012 04:14 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Southern California | 0 | 12-16-2012 03:46 AM |
| WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk | No Limit Motorsport | Exterior Parts (Aero, Lighting, Etc.) | 5 | 10-03-2012 10:03 PM |
