86WORX
Northern California NorCal
finch1750, go_a_way1, undefindedt
Old 04-26-2017, 06:34 PM   #9689
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Anyone in/near San Jose around/able to help me out sometime this week in the evening, or maybe Sunday with installing my tow hook relocator for my license plate?
I'm getting it in the mail tomorrow and from looking at the instructions I'll need a socket wrench and then anti-seize or similar to install, and I have neither of those at the moment.
I can pay in boba or something like that .
I can help ya out! I'm usually free during the week after 5, shoot me a PM with which kit you got so I can check the instructions and figure out what tools we'll need. The only thing I don't have it anti-seize, but a quick stop at kragens or autozone and we'd be set.
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
spike021 (04-26-2017)
Old 04-26-2017, 06:42 PM   #9690
spike021
spike021's Avatar
Originally Posted by JeremyR View Post
I'm scared my vanity plates are jacked up too! I also ordered 6 characters, JCRZC6, but the lady who worked the counter seemed to have a hard time... it's been almost 3 months and I haven't received anything.. I went in on 02/10/2017 :\
So I gave the DMV a call yesterday and the person I spoke with read my number back to me and according to him I did put a '/' at the end, so I _should_, _hopefully_ get it centered like I wanted, but he also gave me the phone number to the department that handles this stuff to double-confirm.
Another thing, he told me lately even though the website says 6-8 weeks for personalized plates that they're taking up to 4 MONTHS.
That'd be awesome! It looks like it actually does come with a small packet of anti-seize! So we'd just need the proper tool(s)!
These are the instructions for it: http://perrinperformance.com/attachment/337445-.pdf
Looks like we'd need a 19mm or 3/4" socket and a way to know how tight it is?
"Install Tow Hook Stem into threaded hole using 19mm or ¾” socket and tighten to roughly 50ft-lbs."
I'm usually not free right away at 5 but I'll let you know. I might actually be available around then tomorrow, if that would work?
spike021 is offline   Reply With Quote
Old 04-26-2017, 06:43 PM   #9691
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I say save that boba money and start investing on tools to fill up that tool box
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
funwheeldrive (04-27-2017), JeremyR (04-26-2017)
Old 04-26-2017, 06:45 PM   #9692
spike021
spike021's Avatar
Hahaha, fair point. But on the other hand, what's the phrase about how a good worker deserves their wages or something? If someone's going to help me out I should be able to do something, even small for them.
Old 04-26-2017, 06:54 PM   #9693
JeremyR
JeremyR's Avatar
Seems like a pretty simple job. I don't own a torque wrench but 50 ft lbs isn't a whole lot, and unless you're doing lug nuts or engine parts, as long as it's tight and you check it in a few days, all is good.
Just let me know when you're free and we'll bust it out, shouldn't take more than a few minutes! And don't worry about paying in boba, save it for some tools
Old 04-26-2017, 07:00 PM   #9694
BigFatFlip
BigFatFlip's Avatar
I meant you buy the tool and do it yourself
Sent from my Pixel using Tapatalk
Old 04-26-2017, 07:05 PM   #9695
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Heh, so camber bolts or tophat bolts just have to be hand tightened and then checked in a few days? Hey, it's not lug nuts or an engine part.
Don't mean to give you a hard time for your comment, but why does nobody value torquing things to spec anymore? Why does the manufacturer even bother specifying torque specs if "good n tight" is fine?
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Old 04-26-2017, 07:54 PM   #9696
JeremyR
JeremyR's Avatar
No hard time at all! I've been wrenching on cars since I was 15, (I'm 30), went to EVC automotive school, and worked in the industry for a while. I used to build and drift Nissan 240sx in a past life, and have ripped down and rebuilt many cars over the years. I'm not saying I am an expert, and I do use torque wrenches on things that are more sensitive (clutches, manifolds, things with gaskets, etc etc, this is what I meant by "engine parts")
I still have lot's of friends who work in the industry, and you'd be surprised how many shops, companies, dealerships, etc etc don't use a torque wrench on every single bolt. If you work in the industry, or wrench cars enough, you can gauge what you can and can get away with not using a torque wrench on. It is really necessary to torque everything to spec? Maybe, maybe not.
And most manufacturers give you a torque range, so even that is not exact, and torque wrench's can often go out of spec as well. There are tons of variables.
When I was a newbie in the car scene I thought everything needed to torque to spec or else I would die! Or the car would explode, but that's simply not the case. and I'm not trying to sway your opinion one way or the next, and i'm not offended or even mad, and i'm not trying to come off as a know at all, cause I'm actually a really humble guy. If you feel more comfortable torquing everything to spec, that's fine. To each his own!
The Following 2 Users Say Thank You to JeremyR For This Useful Post:
BigFatFlip (04-26-2017), Clipdat (04-26-2017)
Old 04-26-2017, 08:04 PM   #9697
Clipdat
Proud of BOXER
Clipdat's Avatar
I actually wouldn't be surprised, a friend of mine has worked as a tech for Acura, Infiniti, and Lexus and he always laughs and gives me a hard time anytime I bring up "torquing things to spec"
It just seems like such an easy thing to do, especially for a boutique shop or when you are DIY. It doesn't make sense to me to not do it, when you have the opportunity to do it.
I'm old and lazy
Old 04-26-2017, 08:10 PM   #9698
JeremyR
JeremyR's Avatar
It's totally an easy thing to do, and I'm actually pretty OCD about things too, but I sold off my torque wrenches and most of my nicer tools when I left the car scene 6 years ago, a socket wrench set and some screwdrivers are all I really have now
Old 04-26-2017, 08:33 PM   #9699
BigFatFlip
BigFatFlip's Avatar
^This. Engineers have to spec out torque for various reasons: manufacturing, safety regulations, to meet quality standards, etc. Tech's use their real world experience generally know what is critical and what isn't, so they use their discretion to be more "efficient" at their job.
Do they have to be strictly followed? Eh, but they are already there, and somebody has already put the time and effort coming up with that number, so why not use it.
I'd sell my shitty tools way before my nicer ones. I still have tools from my grandpa and even inherited some from my father-in-law, some of which he inherited from his grand pa. My OCD also make me send my torque wrenches, calipers and gauges out to calibration every couple of years...
The Following User Says Thank You to BigFatFlip For This Useful Post:
JeremyR (04-27-2017)
Old 04-26-2017, 10:48 PM   #9700
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Ask any mechanic out here, any shade tree mechanic
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
Clipdat (04-27-2017), FirstWinter (04-27-2017), PMok (04-27-2017)
Old 04-27-2017, 01:38 AM   #9701
Kaotic Lazagna
Drives: GR Corolla
It's my FR-S' 3rd birthday today (well, when I got her, her actual birthday was last month). lol.
Kaotic Lazagna is online now   Reply With Quote
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Clipdat (04-27-2017), funwheeldrive (04-27-2017)
Old 04-27-2017, 02:16 AM   #9702
JeremyR
JeremyR's Avatar
lol man i regret selling them, but i thought i was done with cars.. :/
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 01:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1399 02-08-2019 02:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 02:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-09-2013 12:07 AM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 01:38 AM
