Northern California NorCal
finch1750, go_a_way1, undefindedt
Old 06-20-2013, 02:37 PM   #1975
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
What wheels are you going with?
RPF1s. I kept going back and forth, but those are the best bang for your buck.. lightweight, wide, look alright with a drop, cheap. Can't really argue with that choice except they're not the sexiest wheels looks wise. But function > form.
Originally Posted by BlaineWasHere View Post
I wouldn't be able to get the suspension anywhere close to where I wanted it with a wide tire and 35 offset. BUT you have to put +35 if you want 255s and aren't getting coils.
Why would spacers freak you out? With my extended studs my lugs will have MORE threads than stock even with the 5mm spacer to get et40.
P.S. get the tophats with wide tires, camber bolts will move the tire way far in to get the camber, with stock or drop springs you'll risk rubbing. Unless you stay at 225/235 for width.
I dunno I've just heard people say bad things about running spacers and how it ruins the steering feel and can mess up your wheel bearings. Also just the concept of putting metal between your hub and wheel seems weird to me. But if they work, then more power to you.
I guess I'll do a test fit once I get all my parts in and see if I run into any rubbing issues. Will order the tophats if I determine that there will be problems.
Now I'm just trying to decide on what tires to get. Between the v12 evos and R-S3s.. I know Blaine is going to recommend the R-S3s. But I'm still trying to figure out if I want to do a dedicated track set or just keep the RPF1s on full time and get a more DD suitable tire with decent grip.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 06-20-2013, 03:10 PM   #1976
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
The offset it what wares out bearings weather it's the natural offset of the wheel, or with a spacer. Therefore your et35 will cause more ware than my et40 with spacer.
The danger with spacers is NOT extending your studs. That's very unsafe. The H&R spacers I got are also hubcentric. However I'd never use the type of spacers that bolt onto the hub and then have their own studs.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
overlookedx (06-20-2013)
Old 06-20-2013, 03:21 PM   #1977
kster1
kster1's Avatar
Originally Posted by RC51ed View Post
Right now I'm still running the stock suspension. I'm still debating on either the ohlins or kw clubsport 3-way adjustable. Leaning more towards the ohlins because of the price but not definite yet. As for goals, nothing too serious. Weekend drives and a couple track days in the future. I just don't like upgrading to a better suspension in the future if I can get it the first time around. There's not much info on the kw's so I was waiting to find more reviews before I make my decision.
I'm running Ohlins on my car. If you ever want to check them out in person, or want a ride let me know (I'm in Fremont). I also do 4-6 track days per year in case you would like to see them there.
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
RC51ed (06-20-2013)
Old 06-20-2013, 03:38 PM   #1978
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
Oh, nice. I'm in union city. Are you going on any of the drives or meets anytime soon? I don't want to take up any of your time if your busy.
RC51ed is offline   Reply With Quote
Old 06-20-2013, 03:50 PM   #1979
kster1
kster1's Avatar
I'm not planning on attending any of the meets in the next few weeks. After that, I'm not sure. If you would like to see the Ohlins earlier, it's no problem meeting for 10-15 mins. I'm usually free evenings and weekends.
RC51ed (06-20-2013)
Old 06-20-2013, 04:35 PM   #1980
RC51ed
RC51ed's Avatar
I'm in no rush but if I find some free time I'll hit you up to see if your available.
Old 06-20-2013, 04:40 PM   #1981
kster1
kster1's Avatar
Sure, just send me a PM. Thanks.
RC51ed (06-20-2013)
Old 06-20-2013, 04:57 PM   #1982
MyRx
MyRx's Avatar
So much NEGATIVITY in the NorCal OT I figured I'll bring some POSITIVE!
Strano Parts front sway bar is going on the car TODAY! Then test at AutoX this weekend! I anticipate this bar will be much better than all of the name brand offerings for a many reasons. The biggest reason is it was actaully built with FOR the FR-S/BRZ. Most of the other parts manufactures just made a super stiff front bar to match the sorta stiff (but WAY to stiff for GT86) WRX/STi bar they already made to save R&D. IMO almost all of these "off the shelf" set-ups will make the car WAY WAY to stiff. Sways should be used to tune suspension, not "fix" it. Regardless I'll report back!
I also have whiteline camber top mounts, and wheel spacers so I can dial in MORE negative camber and go up to 255/40/17 tires!
Please say you have the latest production of the WL's top mounts and/or it has the improved inserts. I have the same but not yet installed as I'm following up with Robispec's hats. +1 on the Strano bars. They should be an aid in performance and not a bandaid on the driver. What 'stiffness' are you going with?
Old 06-20-2013, 05:01 PM   #1983
BlaineWasHere
Grip>Drift
Drives: FRS
Yeah. I'm not even sure if I'll install the WL top mounts or just bite the bullet and get camber plates...
I'll try all three stiffnesses on the bar. Not sure which I'll start at though, prob the middle.
MyRx (06-20-2013)
Old 06-20-2013, 05:06 PM   #1984
overlookedx
If either of you decide against installing the WL tophats, let me know!
Superfast Jellyfish
Old 06-20-2013, 05:30 PM   #1985
MyRx
MyRx's Avatar
I won't say "don't". Then I won't say "inquire with Robispec's hats". I won't say that because I have the WLs with the proper insert (I think) but it's still a shot in the dark.
Old 06-20-2013, 08:05 PM   #1986
BlaineWasHere
Grip>Drift
Drives: FRS
I'm gonna talk to some peeps with the whiteline mounts and KWs first before I decide what to do...
Old 06-20-2013, 09:03 PM   #1987
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Anybody here can refer or help me on doing HID retrofit? (Baking headlights and stuff) just thinking about it but to have an idea who and where will be awesome before I order a set from retrofitsource. (Just taking off my mind from the car's scar)haa
tintumz22 is offline   Reply With Quote
Old 06-20-2013, 09:09 PM   #1988
BlaineWasHere
Grip>Drift
Drives: FRS
Cars should have scars, don't athletes have scars? What about warriors or gladiators?
Most of the fun is creating them though!!!
The Following 2 Users Say Thank You to BlaineWasHere For This Useful Post:
finch1750 (06-21-2013), tintumz22 (06-20-2013)
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 01:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1399 02-08-2019 02:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 02:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-09-2013 12:07 AM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 01:38 AM
