#15 |
Drives: 2013 Firestorm FR-S
I would guess you can get another 100lbs without gutting the interior etc.. light weight wheels, tires, battery, remove spare kit etc... will go along way. Wheels should make a real difference on a car this light already.
#16 |
Drives: Toyota
The given weight is curb weight and dry weight, so this means with fluids and with 90% full tank.
The lowest weight is 1180 kg. It is for the car with 16" rims, without radio, A/C,.... The low-spec is at 1210 kg and high spec Subaru at 1230 kg. Dry weight would be about +1100 kg |
#17 | |
Drives: 2013 DZE/01 (sold for MX5 ND1)
Toyota: Racing spec is 1180-1190 kg. Base trim is 1210 kg. High-end trim is 1230 kg. BRZ "Estimated average" is 1220 kg. So it'll be more than 2425 pounds dry (that was the weight of the race-prepped car at Nurburgring). |
#18 |
Drives: Miata Club
I assume the drive shaft is steel and will go around 40-70lb just like 240SX. That can be saved by aluminum drive shaft for around 20-25lb of savings. After light weight wheels and better Y split dual muffler, that'll be my next performance upgrade. Since header is equal length, it won't need to be touched. Scion will have very few interior parts other than seats with airbags that can be removed for significant savings.
#19 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
The drive shaft isn't heavy on Subaru's. Maybe 25-30lbs at most, and this one is shorter than your average Subaru driveshaft so probably even less.
#20 |
Drives: 97' 240SX
Will probably get around 2350 lbs with moderate weight reduction. That's light!
#21 |
Drives: First SWP BRZ-L
I wonder if those lightweight seats will be an option that I've seen on some other threads. That'd be a cool option that would still get you good factory fitment and adjustment while lowering the weight a fair amount.
Definitely pulling the spare and throwing a can of fix a flat in there. |
#22 |
Drives: CWP limited
I am just curious how this car is so heavy? I believe my wifes car to be just over 2600lbs (08 civic 4 door lx), seems like with it being a bigger car it would weigh more.
#23 |
THe DX is 2600... if your wifes is an automatic lx it's probably 2700. Valid question though...
#24 |
#25 |
Drives: CWP limited
#26 | |
However, also consider that the FR-S is being designed with even more safety/convenience features in mind (I suspect) and probably has sturdier hardware (brakes, wheels, suspension parts) to support its sporting intentions.
Steve Theodore
2001 Porsche 911 Turbo 1993.5 Toyota Supra TT hardtop - SOLD 2003 Lexus IS300 5 speed (with LSD) 2008 Toyota 4Runner Sport Edition |
#27 | |
#28 |
Drives: Infiniti G35
The US market BRZ will weigh 2770lbs.
Cheers, Hong |
| How can i shave weight? | fernan2 | BRZ First-Gen (2012+) -- General Topics | 15 | 11-01-2011 11:31 AM |
| weight loss | cynic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-24-2011 05:04 AM |
| Another Rumor About Weight | Enzie | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-23-2011 03:00 AM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 11:43 PM |
| FT-86 weight distribution? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-04-2011 11:58 AM |
