#15 |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
I like the foglight idea, even if the user has to cut the fogs with a template... Mainly because some people plan to go F/I and need space for an intercooler
![]() I'd even consider buying these and just cutting the foglight housings myself but a template would be nice.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#16 |
Drives: frs
would you guys sell the backing plate only?
#17 |
#18 |
Drives: 2012 86GTS Race Car #86
and the backing plate would cost $$ ? Any indication would be good as I have the first race coming up in March and it has some big brake points .. one from about 260kph down to 80.. will it work with the Essex Sprint kit?
Thanks for the good work. |
#19 | |
Just for the backing plate for the OEM rotors - we're estimating $275 for the pair. |
| The Following User Says Thank You to Touge Factory For This Useful Post: | 000 Racing (01-18-2013) |
#20 |
Get a Bowl
Drives: 2017 BRZ PP
I noticed a lot of break fade last hill run, so I'll be looking in to this when it comes out. How bad is the install?
#21 | |
Remove wheel Remove Caliper + Rotor Remove wheel speed sensor Remove hub: 4 bolts. Dust shield comes off at this point Install backing plate Install wheel speed sensor Install Rotor + Caliper Trim the inner fender lining slightly to allow room for hose to pass through. Unbolt the windshield washer tank to route hose past it. No special tools required other then your standard wrenches / sockets and a cutter of some sort. |
#22 | |
Get a Bowl
Drives: 2017 BRZ PP
Sent from my SCH-I535 using Tapatalk 2 |
#23 |
#24 |
Get a Bowl
Drives: 2017 BRZ PP
#25 |
That Guy
Drives: 2013 asphalt FRS MT
does the washer bottle get put back?
#27 |
Drives: 2013 WRB BRZ
A nice option instead of the fog light piece for BRZ limited owners would be an adapter piece to screw in place (since we can unscrew the foglights themselves) to mount the ducting to, might be dandy.
Or this already an option? |
#28 |
Let me know when this is available. Gtfrank
Please contact me when this is available. Gt frank.
| FRS bumper duct | VENOM~ | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 12-12-2015 01:15 PM |
| Arrows Japan Brake Duct Cooling Kit & Suspension | BPAuto | Brakes, Suspension, Chassis | 65 | 06-22-2013 10:35 AM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
| Carbon Fiber Brake Cooling Duct | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-25-2012 01:03 AM |
| Brake cooling duct kit | tranzformer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 12-14-2011 02:37 PM |
