#85 |
Drives: 2016 Scion FRS Raven
Can anyone make a small guide on what to buy and what is needed?
#86 | |
Drives: 10 series FRS
and some re-pinning. There are a few diagrams on this forum. but its quite easy. Or you can buy a harness that another member sold. good luck. |
#87 | |
You sure those are JDM? My jdm set had 7. Moto and I got our headlights from the same source. The USDM 10Series/RS1.0/RS2.0 all have 6 wires in the 8 wire plug. |
| The Following User Says Thank You to Knshro13 For This Useful Post: | FRSToyota86 (03-14-2017) |
#88 |
Drives: 2013 Scion FRS
Thanks Moto, I was able to use the information you provided and made a harness. I made use of some Diodes, I was able to keep my DRL and DRL Always on!
Thanks.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
#89 |
My VTEC fluid is full
Drives: EFF JAY
Sorry to bump an old thread... but is there a way to reduce the light output of the LED strip?
I've installed the Monogram lights to my base '14. Everything works as it should but the LED light is just too bright. At the moment, the headlight's LED +/GND leads are connected to the Parking +/GND. Is there another power source I can tap to that would produce a dim LED light? TIA! |
#90 | |
Wheels for Brains
Typically for US market, the FRS LEDs are only active for DRL, which you have to custom spice power from the original DRL source (from DRL resistor source). This is separate from the parking power. Diode Dynamics and Beatrush offer a DRL always on harness kit with a resistor that supposedly dims night time output, but I don't have experience with it. Again, I believe you need to implment original DRL function to use it (aka power from resistor source). There is also a DIY where you wire in an inline resistor. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | iLuveKetchup (03-01-2018) |
#91 | |
Drives: 2014 FR-S
I noticed on a wiring diagragm of the Monogram headlights that Pin 1 is white (LED high), Pin 2 and Pin 3 are not used, and Pin 4 is black (LED ground). Is it possible that the Monogram lights have a green wire, maybe on Pin 2 or Pin 3 and that maybe it would be the LED low? Don't have a photo to check so I'm shooting in the dark here. Did you try the "Always On" module, and I wonder if it reduces the output of the LED? |
#92 | |
Drives: EFF JAY
I don't like the LED strip much and was thinking of just removing the LED light functionality altogether, but this is a good compromise. Thanks so much! I'll try this next. |
#93 | |
Drives: EFF JAY
The Monogram has 6 leads: Red (thicc) - headlight + Black (thicc) - headlight gnd Yellow - high beam + Blue - high beam gnd White - LED + black - LED gnd I've re-pinned to the OEM FRS 6-pin connector as follows: ----------- TAB ----------- ----------------------------- Red | Black | Yellow ----------------------------- White | black | Blue ----------------------------- |
#94 | ||
Wheels for Brains
The major difference is that the LEDs will not work at night. They also don't won't turn on when you use high beam. This is from my general understanding. I haven't wired mine into DRL yet so I can't say with 100% certainty what all of the operational scenarios are |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | iLuveKetchup (03-04-2018) |
| Tags |
| gt86, gt86 headlights, headlights, lhd |
| Plug N Play Super Bright LED Kits @ JWM- FREE SHIPPING! | JWMotoring | Interior Parts (Incl. Lighting) | 166 | 03-23-2014 09:08 PM |
| ECU Plug and Play | Mo707 | Engine, Exhaust, Transmission | 8 | 08-26-2012 12:21 PM |
| Xenon HID Conversion PLUG & PLAY | jarviz | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-01-2012 06:34 PM |
| HID Plug 'n Play Kit | JW89225 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 07-31-2012 01:17 AM |
| Which hid plug n play kit? | huma | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-21-2012 12:10 AM |
