Old 08-23-2013, 02:44 PM   #29
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
@ARK Performance
Thank you for finding this thread and replying to my concerns. I will try again an ask for my brother's asistance this time. I will loosen all the bolts and start tightening from the engine side as you say. Any other recomendation? Like do you recommend hanging just two hangars or do all 4 while i tighten?
BTW I am extremley happy with this. The quality and looks are top notch and the sound is absolutley impressive. Thank you for this as well. I have no problem paying well for a well made product, and you delivered!
Props to you
Pablitomarrero is offline   Reply With Quote
Old 08-23-2013, 03:58 PM   #30
ARK Performance
ARK Performance's Avatar
Drives: Subaru BRZ
@pablitomarerro
My biggest recommendation would be to do it on a lift, it is very difficult to do it on the floor with jack stands and a jack, you are given a lot more leverage when on a lift. Next thing is to make sure all the hangers are in while you tighten the exhaust
ARK Performance is offline   Reply With Quote
The Following User Says Thank You to ARK Performance For This Useful Post:
Pablitomarrero (08-23-2013)
Old 08-23-2013, 04:05 PM   #31
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Originally Posted by Pablitomarrero View Post
@ARK Performance
Props to you
I had the same issue with my GRiP and it was only possible with 2 people. We actually had 3 (2 of us to make sure it was aligned while one of us was under the car positioning it). I had the exhaust on all the hangers and just played with the muffler section until they were aligned properly and tightened those bolts down.
UnOvertime is offline   Reply With Quote
The Following User Says Thank You to UnOvertime For This Useful Post:
Old 08-23-2013, 04:13 PM   #32
Pablitomarrero
@ARK Performance
Well I dont have a lift, so jack stands will have to do. Ill try it again, this time all the way from the engine side. The only thing I adjusted last time was the middle section with the part going to the midpipe fully bolted down. Thnks! Crossing fingers
Old 08-24-2013, 01:21 PM   #33
Pablitomarrero
@ARK Performance
Update: so I finally gave in and went to a muffler shop to adjust it... Try as they may the right side still hung lower. And so I looked at older pictures with the stock exhaust and found the problem: stock exhaust also hung lower on the right side. So the shop just banged one of the hooks holding the exhaust and presto. Perfect. Thanks for your help!
Old 08-28-2013, 01:04 PM   #34
ARK Performance
Drives: Subaru BRZ
sounds good! thank you for double checking and I'm glad you're happy with the system!
Pablitomarrero (08-28-2013)
Old 10-09-2013, 03:43 PM   #35
JLFiechter
JLFiechter's Avatar
Drives: Ultramarine FR-S
@ARK Performance What's the DT-S system's weight?
JLFiechter is offline   Reply With Quote
Old 10-10-2013, 03:52 PM   #36
ARK Performance
Drives: Subaru BRZ
The DT-S is about a few pounds lighter than stock but very minimal
Old 10-12-2013, 07:24 PM   #37
TRD_86
Drives: 2013 86 white
Which outlet tip has larger diameter when look in person DTS or Evo3? This car need the bigger tip to fill that cut-out.
TRD_86 is offline   Reply With Quote
Old 02-05-2014, 08:38 PM   #38
ARK Performance
Drives: Subaru BRZ
Sorry to bring this thread back to life but, our DT-S system is 4.5" tip while the EVO3 is 4".
Anyone else looking to buy an exhaust?
Give me a call or email.
erick@arkperformanceusa.com
Old 02-05-2014, 10:43 PM   #39
TRD_86
^ Pm me, may be I think you have good deal local pick up for DTS and Grip !
Old 03-17-2014, 11:45 PM   #40
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Originally Posted by ARK Performance View Post
We design all our exhausts with flexibility in it meaning you are going to need 2 people to install the exhaust. When installing have one person hold the rear section in the desired location while bolting it starting from the engine back. We know its a little more work but its so it fits any FR-S and BRZ for even the smallest differences in the cars, hope this helps!
starting from engine back means I gotta unbolt everything from the pipe right?
bhbnuckle is offline   Reply With Quote
Old 04-14-2014, 11:08 AM   #41
chas3wba0
chas3wba0's Avatar
Drives: Yes
Holy thread resurrection Batman, but I just installed this exhaust over the weekend and felt like chiming in on how sweet this exhaust sounds... the tone is deep AF! And it looks amazing too.
Combined with the uncatted Perrin front pipe that I already had, it's pretty damn loud. I'm quite sure I wake up the entire street with cold starts, so I may have to throw the factory front pipe back on soon to see if that tones it down a bit.
Despite being a loud exhaust, it's quite easy to shut it up on the freeway with the right throttle input. Hums a bit under light acceleration but I wouldn't describe it as "drone". WOT is audible sex.
According to the butt dyno, car also feels torquier down low, but not sure if that has something to do with the Perrin inlet hose I installed at the same time..
One tip sticks out further than the other (only noticeable to me), I think this may have to do with the Perrin front pipe being slightly shorter than the factory one (took a bit of force to mate it to the midpipe), so I should be able to correct that when I swap out the FP.
Overall, great system @ARK Performance
[ame="https://www.youtube.com/watch?v=3azs5o9YCxA"]ARK DT-S with Perrin Overpipe & Test Pipe - YouTube[/ame]
Update for anyone who cares: Putting the stock front pipe back on toned it down a bit, and now it is just a nice deep tone without the obnoxious cold-start. The tips are now perfectly aligned as well: I was using the factory donut gasket on the Perrin front pipe which added a bit of extra clearance between that and the midpipe.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 04-14-2014, 01:05 PM   #42
R3VOLUTION
Drives: 2012 Evo X - STOLEN
Any comments on how an unresonated midpipe + UEL manifold makes this sound?
R3VOLUTION is offline   Reply With Quote
Search this Thread:
Advanced Search
Perrin Catback Exhaust Installation and Review! Sony Engine, Exhaust, Transmission 316 01-24-2016 02:01 PM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 09:27 PM
Review of ISIS Street Catback exhaust sirhc Engine, Exhaust, Transmission 24 10-29-2012 05:57 AM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 04:25 AM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) -- General Topics 3 12-13-2011 09:03 AM
