Old 12-13-2012, 08:48 PM   #57
orthojoe
ECU_1 GT_RPM RPM
ECU_2 GT_SPEED Vehicle speed
ECU_3 GT_THROTTLE Throttle position sensor
ECU_4 GT_BRAKE_PRESS Brake pressure
ECU_5 GT_STEER_ANGLE Steering angle
ECU_6 GT_BRAKE_SW Brake switch
I suppose that's better than nothing....
I'm a little surprised that engine coolant temp isn't on there since I like to make sure that temps are under control at the track and usually the dash gauges on cars aren't very accurate, but the rest of the info is great. brake pressure, steering angle, tps are great to have for data analysis.
orthojoe is offline   Reply With Quote
Old 12-13-2012, 08:55 PM   #58
ECT and Oil temp were the two big ones I was looking for tbh :p
Old 12-13-2012, 11:09 PM   #59
orthojoe
Yeah, ECT should be there since it's available through any obd2 port. It looks like AiM getting the info through the CAN line in the obd2 port. Hopefully they can decode more channels in future updates. The Porsche Siemens ECU grabs a ton of great data including ECT, oil temp, and oil pressure
Here's the screenshot of the config screen:
Old 12-17-2012, 11:46 PM   #60
DarkSunrise
DarkSunrise's Avatar
OP you might enjoy this video:
Old 12-18-2012, 01:36 AM   #61
cf6mech
Drives: FRS Silver LS1 swapped.
Buy the OEM tires from the other member : )
cf6mech is offline   Reply With Quote
Old 01-12-2013, 12:59 AM   #62
orthojoe
Just a quick update on AiM solo DL:
I received my BRZ this week and connected my AiM Solo DL through the OBD2 port tonight. It works perfectly. All channels are able to be logged as described. This is plug an play confirmed.
2013 Subaru BRZ
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 07:56 PM
top speed JLMtm Scion FR-S / Toyota 86 GT86 General Forum 56 10-30-2012 10:23 AM
D-SPEED ANREX Cosmetic Modification (Interior/Exterior/Lighting) 2 10-29-2012 08:47 AM
BRZ top speed speedracer38 BRZ First-Gen (2012+) -- General Topics 66 07-08-2012 04:37 PM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 11:59 AM
