Old 12-11-2012, 11:20 PM   #29
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I live south of San Francisco where fog and mist are common on cold mornings, and sometimes throughout the whole day.
However, I barely notice a difference in light illumination with my Corolla that is equipped with both Halogen low beams and fog lights. On my Prius with LED low beams but halogen fog lights, I can see the difference and it's not that big of one. There is a "dead spot" close to the front bumper of the car where the low beam fades because of the cut-off point. When I turn the fog lights on, this space is illuminated by the fog lights.
The main reason I want them so bad is because of appearance. The front of the FR-S looks too plain with the faux vents on the side, the fog lights make the front stand out a bit more (in my opinion). Also, in the night, I've always found it nice when I see a car with both low beams and fog lights on, it looks more upscale (in my opinion).
My FR-S isn't even driven in misty or foggy conditions to be honest. So there, I want it for looks.
Veloist is offline   Reply With Quote
The Following User Says Thank You to Veloist For This Useful Post:
TheGuyWithTheFireStorm (12-12-2012)
Old 12-11-2012, 11:44 PM   #30
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
With my '92 Supra I ran fog lights all the time; made a huge difference in visibility at night.
Pooverdam is offline   Reply With Quote
Old 12-11-2012, 11:47 PM   #31
Ingen
Drives: Ultramarine FR-S 6MT
I want them because you can't see the stripes on the road when it rains without the stupid things, it all gets lost in the glare from street lights.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
The Following User Says Thank You to Ingen For This Useful Post:
Lonewolf (12-11-2012)
Old 12-12-2012, 12:04 AM   #32
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
They're supposed to help show the road in front of you during conditions of heavy fog or snowfall where the weather condition ends up making your standard headlights mimic shining against a wall 2 feet in front of you. But in the end, if your headlight is just making a wall of fog more visible in front of you, the foglight is just making the wall of fog more visible at the bottom.
And in the grand scheme of things, all they really end up doing is just brighten up that dark spot between the front of the car below the headlight and projected light that is reflected off the ground a few feet in front of you (since the light is 'beamed' outwards, theres a dark spot under the beam that the light does not get to)
The only time you'll really notice any lighting difference is during those long stretches of highway or dark roads where there is no streetlamp to help shine the way. But high beams work better in this situation (as long as there is no one in front of you going the opposite way, or isnt close by). Plus when i activate my highbeams, the fogs get disabled anyways, since the high beams just makes everything a ton more visible making the fogs redundant.
Think of it this way. imagine you are staring straight down a road through a monitor. and the monitor is split horizontally in 3 (not evenly, probably something like 80% middle section, 10% for both top and bottom sections). the top section and botton sections are both blacked out. the middle section is not. The middle section is your headlight. the foglight would make the bottom section visible, so anything that would be hidden by that 10% is shown.
Old 12-12-2012, 12:07 AM   #33
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
After seeing the way they've been implemented I want nothing to do with them.
For me, I would pursue something custom but I'd rather put my efforts and money elsewhere.
Useful fog lights to me is having sufficient illumination to drive with them alone. That is, provided they are aimed correctly and don't blind oncoming motorists.
CircuitJerk is offline   Reply With Quote
Old 12-12-2012, 12:11 AM   #34
LIKEABOSS
LIKEABOSS's Avatar
Drives: 2013 Boss 302 & 2013 FR-S
Now would be interesting is if Toyota released a brake cooling kit using the fog light opening like Ford does with the Boss. I'd be interested in that.
LIKEABOSS is offline   Reply With Quote
Old 12-12-2012, 12:22 AM   #35
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
If they actually installed the proper color temperature Yellow bulbs they would work properly, my 97 Legacy GT had fogs i put yellow bulbs at 3000K and during crappy weather it cut through the haze, same with my E36 325is, and E36 M3 had yellow bulbs in fogs and they did make a world of difference. also because fogs just look cool. but umm they weigh to much because race car.
DanoFA20 is offline   Reply With Quote
Old 12-13-2012, 11:39 AM   #36
Slammin
Drives: 1995 BMW M3
On my 1995 M3 the fog lights made a huge difference. The stock headlights suck on low beam anyhow. Fogs made up for it.
BUT on my 2003 330i w/xenons, there is no difference.
I put a set on my Range Rover Classic as well because the stock lamps suck so bad.
Fogs are cool, but if you don't need them, you don't need them.
Slammin is offline   Reply With Quote
Finally got my Whiteout FR-S, lets drive. Wolfkiller Southern California 10 11-22-2012 09:00 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) -- General Topics 33 02-15-2012 02:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 01:05 AM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 01:51 AM
GM Lets Another Die S2KtoFT86 Other Vehicles & General Automotive Discussions 11 12-20-2009 10:51 PM
