Old 02-27-2013, 08:49 AM   #169
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by FA20Club.com View Post
over pipe on its own is only complimenting the full exhaust upgrade since it doesnt affect the secondary cat you wont have much negative affects. the over pipe is meant to compliment a car equipped with front pipe and exhaust. at that point the only restriction will be the header itself.
So does it only run extremely rich with the overpipe and front pipe when the front pipe has no cat?
Is there a real danger of engine damage from swapping exhaust components?
sierra is offline
Old 02-27-2013, 08:50 AM   #170
FA20Club.com
Drives: 2013 White Out FR-S
not going to have any engine damage just wont be maximized. mainly affects are from the decatted front pipe
FA20Club.com is offline
The Following User Says Thank You to FA20Club.com For This Useful Post:
ATL BRZ (02-27-2013)
Old 02-27-2013, 08:57 AM   #171
sierra
Thanks for that. I'm opposed to deleting cats because they do a great job, so it wont be a problem for me.
sierra is offline
Old 02-27-2013, 10:44 AM   #172
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by soros151 View Post
If anything I would expect a rich condition with no cat and the stock air box. No cat = a bit of less friction = faster air velocity = gasses exit faster the through the exhaust side = intake air comes in faster = MAF registers more air going in = ECU throws more fuel to compensate for the additional air coming in. I understand the point of having to tune the car for maximum hp extraction, but unless taking the cat out creates a CEL, then I would wait until everything else is maxed out.
Sent from my HTC VLE_U using Tapatalk 2
Yeah, I was just going to say... IF going to a different over / front pipe or just front pipe or just catback whatever, result in a true increase in air flow the load the ecu see's will go up and as a result more fuel is added. This can be corrected with a tune.
mad_sb is offline
MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 0 11-08-2012 10:09 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 02:10 AM
