#29 |
Drives: Scion FR-S
#30 |
Sounds like severe detonation to me. Can't be 100% without hearing it in person. Could be a fuel injector that isn't fully closing and allowing fuel to leak into the cylinder on the exhaust stroke.
Does sound terminal for the engine if they don't get it fixed before the piston explodes (if it is for sure detonation). |
#31 |
Sarcastic SOB
Fuel getting to the intake and detonating. So, the intake valve must be staying open too long, no? I'm not a mechanic, just using logic. Somehow the fuel must be leaking in during the compression stroke.
Otherwise a fuel injector mis-timed or a leak in the valve maybe? There must be enough leak for hot gas to contact and ignite fuel vapour. Aside from OBDII perhaps check compression to try and find offending cylinder and maybe check VVTi cam angles.
#32 |
yikesssss. good luck man seriously.
Encity's Firestorm MT Car Journal:
http://www.ft86club.com/forums/showthread.php?p=252545 |
#33 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
OP please make sure to keep us up to date with the result in case this is a factory screw up or an actual failure and in case anyone has future similar issues. |
#34 |
Drives: fr-s
what kind of gas are you using?
#35 |
The Mechanic
Drives: Civic Turbo,FR-S
sounds like a timing issue
#36 |
Drives: 2013 Raven FR-S
Well if they don't want to service it under warranty- make sure you blow it up before your warranty expires... I wouldn't want to keep an engine thats gone through that much premature wear! Who knows how bad the heads look with all that detonation.
#37 |
I've got some news. The director finaly gave me a phone call after my call to another dealer of the region and my idiot complaint to Toyota Canada. He's kind of piss of about me because i he's thinking i'm not fair with them ...
Anyway they told me that it's not the exaust and it's not about the air comming into the engine. They tested a lot of electronic part to control the air flow and the injection system. So the toyota ingineer would probalby order to change the engine and ship the old one back to them for further investigation. Finaly after more then 2 weeks they think it's the engine And to blame my lack of patience that seems that before my numerous complaint the owner told them that maybe they should pay my month for compensation. So now they are pushing it to me that i was not fair and maybe they will not pay my month cause i've called another dealer and toyota canada ... So we will see what happen really soon. Thks guy for your support. Hope the best for me. |
#38 | |
Drives: SWP BRZ
Good luck. |
#39 |
Drives: 2013 FR-S Hot Lava
Don't let them make you out to be the bad guy.
They totally blew you off and it took a formal complaint for them to take action. Tell them to shut the fuck the up and fix the car.
Live to drive another day
#40 |
Some news after excellent compression and leak test. They tested the injector and the #1 is faulty. So tha't was causing the bakcfire intake.
Finaly after 3 weeks they checked the injector
#41 | |
Grip>Slip
#42 |
Glad you got it fixed.
| Tags |
| backfire, engine, intake, problem |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 01:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 09:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 02:31 PM |
| Backfire when shifting | canu_50 | Issues | Warranty | Recalls / TSB | 39 | 09-27-2012 02:55 AM |
| intake | whitefrs | Engine, Exhaust, Transmission | 1 | 08-30-2012 12:19 AM |
