| View Poll Results: Coilovers? | |||
| KW Varient 3 |
160 | 47.20% |
| BC (what varient should I get?) |
48 | 14.16% |
| HKS Hipermax IV GT |
21 | 6.19% |
| Cusco (what varient should I get?) |
15 | 4.42% |
| KSport Kontrol Pro/D2Racing RS |
10 | 2.95% |
| Megan |
12 | 3.54% |
| Tein (what varient should I get?) |
54 | 15.93% |
| Tanabe Sustec Pro |
1 | 0.29% |
| Stance |
18 | 5.31% |
| Voters: 339. You may not vote on this poll | |||
#57 | |
Because compromise ®
Drives: Red Herring
#58 |
Drives: Black frs project
AMEN it cost us over 5K to get to 3" drop with stock camber curves and the roll center/bump steer corrected..oh the car only has 3" compression travel YOU do the math on a 2.5" drop. Who needs springs anyways?/? lol
![]() ![]() ![]() we still have full travel and due to the shorter tire we also have no rubbing even at the track going over curbs when nessisary |
| The Following User Says Thank You to robispec For This Useful Post: | ill86 (12-07-2012) |
#59 |
Drives: 2013 FR-S Ultramarine
@robispec - are you keeping full travel due to strut housings and springs that are designed to be low or do you have more than that going on? I don't really want to be that low but if I could drop 1-2" and INCREASE bump travel that'd be amazing.
Thanks, Nathan |
#60 |
we raised the upper strut mount in the front and used the ground control mount which yields 2" raised front mount and raised the rear shock mount up 2 " too (needed to "clearance" the sheetmetal reeinforcement back there to get this to work though).
Parts available for this sometime in Jan ready for the time attack season! custom front lower control arms give you castor,camber,track,anti-dive, and roll center adjustment/correction, with bumpsteerable tierod ends fixes all the geometry issues you have caused |
#62 | |
Drives: Supercharged Saturn ION
For strictly street use I would probably look into BC Racing or Stance coilovers. I've been on many forums and can't say I've ever seen a complaint about them. Plus they are priced appropriately for most owners. |
| The Following User Says Thank You to NJA For This Useful Post: | RRnold (12-07-2012) |
#63 |
Scrape Master
Drives: Goal: Oldest FRS State Side
As the guy above me said he has no funds, no funds to me means coil's around 1k. For 1k you can get spring/shocks that are better then the 1k coil and give a slammed look.
#64 | |
Anywhere you have large numbers of people who actually care about performance, track ability, and comfort you're going to have people that dislike BC and their ilk. Nathan |
#65 | |
Scrape Master
#66 | |
![]() There are a bajillion people on Nasioc. Many of which are hellaflush fanboys. The people who are serious about tracking and performance in general have gotten over the BC phase. The problem with WRX's and even the older RS's I have loved for so long is that they are now cheap. Cheap enough that 16 year old highschool students can buy them. That's awesome on one front because it's exposing new people to great cars. It's bad because many of those people don't have a clue what good handling is and think, "It's low and stiff yo, uber good handling!" when really that gokart feeling is the bumpstops and their car's limits have been drastically reduced even from the stock configuration. Just looking at the BC setup for this car I can see that the amount of bump travel available is miniscule. That means they're either inordinately stiff to avoid the bump stops, or they're riding on them. Neither of which is good for performance. Lastly, with such short springs the droop travel before things are just hanging limp is minimal, further compromising the performance. This can result in lifting tires while cornering, and loss of traction over uneven surfaces. Let's not get into the quality of the damping or "adjustment" they offer. Nathan |
| The Following 2 Users Say Thank You to SubieNate For This Useful Post: | ASSALBERT (12-10-2012), Racecomp Engineering (12-08-2012) |
#68 | |
Scrape Master
#69 |
Drives: Whiteout FR-S
Koni's are 770 + 230 for some springs or you can get the GC street system that's height adjustable for 1350 so you can drop it for shows. I would go with one of those two or just get some springs on the stock struts which are fine until you can afford something like KW. I wouldn't personally run BC or Stance on my car but I know lots do and are happy but that's a decision only you can make. Is there anybody local to you with aftermarket suspension?
#70 |
| DIY BC coilovers | RWD-boxer | DIY (Do-It-Yourself) Guides | 1 | 11-05-2012 10:07 PM |
| Bc br coilovers | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 10-21-2012 12:44 AM |
| M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS | AMPLIFIED MOTORSPORT | Brakes, Suspension, Chassis | 0 | 08-16-2012 03:45 AM |
| Coilovers vs Springs – What are coilovers and what’s better? | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-30-2012 01:24 AM |
| D2 coilovers | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-27-2012 04:50 AM |
