#197 | ||
Drives: '23 BRZ Limited
Yep. Depending on the BBK there are some that actually add rotational weight which is bad. My desire to get the car as light as possible whilst keeping it streetable means I'm likely going to go with the 4-pot Wilwood kit. Quote:
I previously ran Carbotech XP10 on my Miata with Wilwood's front and rear. I never had an issue with brake temps, but from the other guys like Andrew at TrackSpeed and Emilio at 949Racing, keeping them cool dramatically extends their life. |
#198 | |
#199 | |
#200 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
At a significant cost
![]() What would you recommend? I've got probably 10 lapping days under my belt, tons more auto x. Might average 3-4 lapping days a summer if I am lucky due to not having a track near me. 260WHP/195WTQ, 255 Z2s. |
#201 | |
2022 BRZ Build 2013 FR-S Build |
#202 |
#203 | |
Yes, this is very true. One day we even took it out and shared it with a friend, I think we pulled 12 20 minute sessions, ours were always back-to-back. No problems. I'm hoping the smaller Wilwoods + XP10 or XP12 + ducting will be enough since Hallett is relatively easy on brakes for momentum cars. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | CSG Mike (06-16-2015) |
#204 | |
![]() Like I was I saying, it's not always the end all type of statement to run ducting. Side note, Miata brake setup logic can't be used on the BRZ/FRS. I've seen Spec Miatas run XP8 or XP10s for full seasons and a half on RA1s. LOL! |
#205 | |
Good to know on the Carbotechs, perhaps that's why I read lots of problems with people getting them bedded properly in the Miata world. You've really got to hammer them until the smell like a burnt clutch for a good transfer layer. Yeah, BRZ is definitely heavier and more powerful, but I'll on Direzza Star Specs instead of R-comps. I'll just have to wait and see! |
#206 | |
Drives: '13 Raven FR-S, MT
. ck |
#207 | |
#208 |
When we hot lap, we run much more aggressive pads on factory calipers at minimum for Laguna on street tires. It's pretty frustrating running lesser setups as brake management is more of an issue if you want to continue lapping a consistent pace.
#209 |
OK so in my case, what would you recommend for pads since I'm going to use the Wilwood kit (32lbs off the front of the car!), that I can run all the time or won't need a special procedure to run a street/AutoX pad on? I was thinking XP12s and just deal with dust/noise on the street since they aren't hard on rotors and they dust doesn't destroy your wheel finish if it gets wet. Carbotech used to stay not to switch between the AX6 and the XP series, but I thought remembered Emilio saying this isn't true anymore. Thoughts? I'm open to other brands, but I've got a bunch of experience with Carbotechs on two different brake setups on Miata's and always liked the feel on the pedal. |
#210 |
Drives: 2014 BRZ
I run XP12s on the street during the track season. They aren't very noisy IMO.
I occasionally switch to street pads (stock) and haven't had any issues with the compound swapping. Seems that daily driving pretty much removes all the brake compound layer from the rotors.
| The Following User Says Thank You to Sleepless For This Useful Post: | CSG Mike (06-16-2015) |
| Anime Discussion Thread | ERA | Off-Topic Lounge [WARNING: NO POLITICS] | 2688 | 05-05-2023 06:10 PM |
| Gundam Universe - General All Discussion Thread | poormans_LFA | Off-Topic Lounge [WARNING: NO POLITICS] | 273 | 03-24-2014 12:45 AM |
| S2000 vs BRZ at the track: track oriented discussion | CSG Mike | Tracking / Autocross / HPDE / Drifting | 33 | 01-13-2013 07:54 PM |
| Track/Racing Discussion | Allch Chcar | Tracking / Autocross / HPDE / Drifting | 9 | 05-26-2012 05:39 PM |
| Forza 3 vs. GT5 Discussion Thread | Snaps | Off-Topic Lounge [WARNING: NO POLITICS] | 386 | 03-06-2011 01:10 AM |
