#141 |
86 Nut
Drives: 86 Satin 6MT High
Guys a fav pls, please check your oil level and report?
#142 |
Drives: Toyota 86 (High) - White
I checkedmine a week ago and all was still 100%
Then again I only had 1500km then. |
#143 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
8000km, still at the correct level and I've never topped up.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#144 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
7500km sat at 100%, did oil change run another 3000km still 100%. Put a TRD filter in, added into the filter to lubricate the filter, 1000km still 100%.
In my opinion this car does not use oil, I am on 12000km, taken her through all types of driving and never added a drop of oil. Checked hot and cold conditions. Coolant is stitting about 3 cm from low, while,cold but after a run to work I check and level is back to high. What's the issue GeeTee |
#145 |
Drives: Toyota 86
Serviced mine in Sasolburg. Was the first one they serviced, took the morning off to watch them to ensure the correct oil was used. Had to leave the car there for the whole day as they forgot to order the correct oil and filter. It was strange that the new filter is also a Subaru branded item. The service is straight forward so no need to worry about the messing it up.
#146 |
Drives: Toyota 86, Pearl White, Manual
Im on 5000. Oil change done at 1800. Check regularly now and fine...
#147 |
Coolant is always half at cold and always full at warm...
#148 |
The voice of reason...
Drives: 2012 Toyota 86 6MT Standard
#149 |
86 Nut
Was over filled from new. After oil change again over filled. Sitting at about 5mm above 2 nd hole.
#150 |
Drives: Toyota 86 Black (Standard)
Oil level still fine after 6000km, coolant level still just above full when engine is cold. (no top ups)
#152 |
Drives: 86 HS AFE filter, BRZ Xors, Kaymak
Hi guys. Has any one been able to get hold of any 0W20 here in South Africa? Pulling my hair out trying to get some. Only Fuchs have any but its Silkolene Pro R (bike racing oil). Their Titan GT1 would be brilliant but they import the stuff from Germany!
#153 |
When you have your car serviced they'll replace it with 5W30.
The dealer asked for a lead time of 2 weeks so they can source the correct oil.
95RON SAV Tuned |
