#113 |
BAMF
" I also forgot to tighten the exhaust clamp and my AP catback hit the ground and was dragged for over a mile into the pits"
Still didn't answer my question, the above is a direct quote from your build thread. What did you not tighten to cause the exhaust to INITIALLY fall off. If you don't understand what initially means, you can look it up in a dictionary. |
#114 | |
Track Junkie
Drives: Faster than the Stig!
Dont know what vivid promised you man but like i said you are not me and you were not there, i had 4 witnesses that saw an exhaust pop off, we re tightened it and it still popped off. Giving them the benefit of the doubt was my mistake as well as purchasing a exhaust with cheap connections. Every single person here has bashed vivid with their connection setup, you are the only person who is defending them and we all know why! Now please go post on vivid's threads how much you love them and their products. Good luck doing your thing for them man, i have spent over 30k with them and look what i got........
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#115 | |
BAMF
You still haven't answered my question as to what you didn't tighten to cause it to fall off the first time. |
#116 | |
Track Junkie
The slip joint connecting the Y pipe to the mid pipe popped off, i thought i had not tightened it enough causing it to pop off. We checked the exhaust and the only thing damaged was the mid pipe since it hit the ground on the tracks uneaven surfaces. The slip joint was fine so we reconnected the mid pipe to the Y pipe and had the track mechanic inspect it. He checked it and said it was good to go, my next track day the pipe popped off again so this would discard your theory of me forgetting to tighten the slip joint. Then the right cannister was popping off and then the welds tore. I think this was clear enough.
#117 | |
BAMF
#118 | |
Track Junkie
Anyways i hope you dont have any trouble with your exhaust but do understand that the abuse from Auto-X has nothing to do with the abuse of the track. Here is why: -Higher speed -More vibrations -WOT almost all the time -More Heat -Uneven road surfaces and bumps that cause things to get loose specially while cornering or at a high speed. -While auto-xing you only do a run and stop you dont run the car for over 20 minutes non stop at full throttle.
#119 | |
BAMF
| A few problems...but how bad are they? | deedz | Issues | Warranty | Recalls / TSB | 20 | 07-21-2013 03:27 AM |
| No CEL problems here | BRZranger | Issues | Warranty | Recalls / TSB | 41 | 12-08-2012 02:36 PM |
| bluetooth problems | whitefrs | Electronics | Audio | NAV | Infotainment | 1 | 10-17-2012 07:13 PM |
| car height problems? | industrial86 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 10-03-2012 08:43 PM |
| Do you think this car is going to have some problems? | Huss | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-21-2012 02:48 PM |
