Old 09-16-2013, 10:48 AM   #407
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm sure this is covered somewhere in the thread but there is no way I'm reading all this right now. When I open the custom PID entry area, I don't get the last entry field. Is this only available on the paid version? If it is, it would be nice for someone to add that fact to the FAQ post. If it's not true, what the heck am I doing wrong?
I also enabled the coolant temp gauge and have an odd problem. The digital value displayed is correct, but the needle points to a different value. Any ideas?
Old 09-16-2013, 10:22 PM   #408
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by garfull View Post
Just pull the rubber mat out and add a plate to extend it out. I originally did this to hold my cell phone but the Nexus 7 fits perfectly in there too. Not recommended for the track because it will tip back under hard acceleration. I am planning to add a couple tabs at the top to prevent tip over.
Nice. May want to check out tetrax magnetic fastener. Works well for my S3
Sent from my Nexus 7 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 09-17-2013, 01:37 AM   #409
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Wepeel View Post
So it seems like when you pull a freeze frame or fault log, the Vehicle Calibration ID is reported. Does anyone know if there's a way to access this if you don't have any DTCs?
Under the main torque log, Adapter Status: Calibration ID.
There's a listing in this thread of vehicle-specific PIDs you can manually enter.
I looked through the whole thread and the only PIDs identified are the standard ones and one custom PID (Oil temp).
Old 09-17-2013, 02:25 PM   #410
stugray
Can anyone post a link to the SAE J1979 OBDII standard that can be downloaded?
It really pisses me off that the only places I can find that doc want me to pay for it.
What a scam!
Old 09-17-2013, 02:26 PM   #411
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Warning, DO NOT BUY a PLx Kiwi 2 Bluetooth.
I finally got mine, it works on nothing......not my FR-S, not on a ford, not on a Chevy, not on a Dodge, not on any of my friends cars I have tried it on. All it dose is go through all the ECU protocols and than report that it cannot connect to the ECU.
Back to the cheap China one that works.......go figure
IceFyre13th is offline   Reply With Quote
Old 09-18-2013, 01:52 AM   #412
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
what would happen if you used one of these y connector?
[ame="http://www.amazon.com/OBDII-Splitter-J1962M-2-J1962F-145802/dp/B000TMCX72/ref=sr_1_6?s=automotive&ie=UTF8&qid=1379479850&sr= 1-6&keywords=obd+extension+cable"]Amazon.com: OBDII Splitter Y Cable, J1962M to 2-J1962F, 1ft (145802): Automotive[/ame]
[ame="http://www.amazon.com/Right-Angle-Splitter-Cable-Female/dp/B00EEDOWU8/ref=sr_1_7?s=automotive&ie=UTF8&qid=1379479850&sr= 1-7&keywords=obd+extension+cable"]Right Angle OBD II 2 Y Splitter Cable 1'/30cm 1x Male and 2x Female J1962 Ports : Amazon.com : Automotive[/ame]
can you connect the mini bluetooth reader and another reader at the same time. or will the ecu only allow for one device to connect to it at a time?
garfull is offline   Reply With Quote
Old 09-18-2013, 06:14 PM   #413
IceFyre13th
Drives: Mazdarati
Only one at a time, I wanted to do that with the Flux2 display and Torque through Bluetooth........UniChip Jack advised me not to as the readers will probably lock up.
The Following User Says Thank You to IceFyre13th For This Useful Post:
garfull (09-18-2013)
Old 09-18-2013, 06:24 PM   #414
FRSRAVEN
Anyone having an issue with the oil temp PID? When activated, it starts reporting, but then locks up after a few minutes. Sometimes it will sporadically update, but for the most part its frozen.
While its frozen, if I go into settings and select TEST custom PID, it says no data.
FRSRAVEN is offline   Reply With Quote
Old 09-18-2013, 11:54 PM   #415
garfull
garfull's Avatar
just added it couple days ago when i found this thread. no issues here.
Old 09-19-2013, 04:12 PM   #416
IceFyre13th
Drives: Mazdarati
I just got this, http://www.scantool.net/obdlink-mx.html
Yes it has a high price, but it works on every car I have tried it on so far.....and it really dose make the Torque app run faster, refresh rates are super fast.
The software it comes with, OBDwiz, is nice too. Still paying with this, more later, running around town with a laptop is a pain.............
Their android app, OBDlink has some cool features.....being able to change the display type without deleting it first is real nice.
Old 09-19-2013, 05:13 PM   #417
FRSRAVEN
Same one I have. Works well, minus the issue with my oil temperature PID.
Old 09-20-2013, 12:04 AM   #418
IceFyre13th
Drives: Mazdarati
My Oil temp PID works, you on Torque Pro or free version.......wont work on free
Old 09-20-2013, 07:37 AM   #419
Hoey
Drives: Black GTS
Just got my replacement unit (some cheapo one from eBay).
It reads oil temps now, but it reports 255,000 under full throttle and 5,000 at idle.
Pretty sure it's reading something different...anyone else had a similar issue?
Hoey is offline   Reply With Quote
Old 09-20-2013, 08:11 AM   #420
FRSRAVEN
I'm using torque Pro.
Mine definitely isn't working. Double checked PID settings, they are correct. I think I've changed another setting in torque that might be messing with the custom PID.
Would changing the default temperature scale (F instead of C), interfere with the custom oil PID which was setup for C?
android, app, boost, gauges, torque
Search this Thread:
Advanced Search
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
