Old 02-28-2013, 03:55 PM   #239
aiiee
Drives: 2011 Porsche Cayman S
Originally Posted by xjohnx View Post
I don't see any reference to it in the shop manual.
Sorry, I forgot where I was. Note my car.
aiiee is offline   Reply With Quote
Old 02-28-2013, 04:15 PM   #240
aiiee
Originally Posted by reeves View Post
Was this a custom PID you added? I only see Method 1 & 2 on my Torque app.. I have the paid version too.
It's under the "Other" predefined sets for extPIDS. But apparently it won't work on the BRZ
Old 02-28-2013, 05:09 PM   #241
reeves
Well I guess it's not really important to monitor the tranny temp anyway.. unless you're autocrossing alot.
reeves is offline   Reply With Quote
Old 02-28-2013, 06:07 PM   #242
xjohnx
Grip>Slip
xjohnx's Avatar
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Brody602 (03-01-2013)
Old 03-02-2013, 02:57 PM   #243
aiiee
Originally Posted by andreyiv View Post
No problem. PM me and I'll help you through the process I went through to find it.
PM sent!
Old 03-06-2013, 12:48 PM   #244
aiiee
PM sent!
bump. You still around andreyiv?
Old 03-13-2013, 11:00 PM   #245
aiiee
Should have known
Old 03-15-2013, 06:28 PM   #246
Trac Toy
Trac Toy's Avatar
I've got a Samung 7" tablet and seem to be unable to find the torque subfolder when I've got it plugged into my PC. I want to be able to add the couple of dashboards provided in the first post.
Any Suggestions? I've already got the "show hidden folders and directories" chosen.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 03-15-2013, 09:07 PM   #247
Yruyur
Yruyur's Avatar
Can you use the built in my files app to move them from the extsd to the internal sd?
Edit: yeah this should work. I just looked. Once you tell my files to show hidden then you can see the torque and dashboards folders. You want to send me some of these dashboards you are working on?
Old 03-18-2013, 08:19 PM   #248
reeves
Originally Posted by developer View Post
Using some of the information I have gleaned from other posts I have come up with what looks like a very accurate reading of how much fuel is in the tank. It seems to be much more accurate than the default fuel percentage that is in Torque.
Torque PID setup for accurate fuel remaining.
PID: 2129
Long name: Fuel Remain (or whatever you want)
Short name: Fuel Remain (or whatever you want)
Minimum Value: 0.0
Maximum Value: 100.0
scale: x1
Unit: Gal
Equation: ((A*13.2)/100)
OBD Header: 7c0
The 0 in 7c0 is a zero not the letter O.
This is so accurate for me is downright scary.. accurate within >0.1 gallon every time I refill, regardless of time, weather, location, station brand, etc.
Thanks for calculating this!
The Following 2 Users Say Thank You to reeves For This Useful Post:
Brody602 (03-20-2013)
Old 03-20-2013, 06:32 PM   #249
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
PID: 2129
Minimum Value: 0.0
scale: x1
Unit: Gal
OBD Header: 7c0
Thank you for your contribution, I have added it to the first page, sorry for the delay :happy0180:
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-20-2013, 08:12 PM   #250
Yruyur
Yruyur's Avatar
Did this help?
Old 03-20-2013, 08:24 PM   #251
Brody602
Drift King
Brody602's Avatar
Did this help?
Noticed in your previous post you asked for the dashboards he was working on, I believe he was referring to the other dashboards a previous user shared with us, I've added them to the first page, 3rd post I believe just scroll down
The Following 2 Users Say Thank You to Brody602 For This Useful Post:
keen as (03-20-2013), Yruyur (03-20-2013)
Old 03-21-2013, 11:11 PM   #252
so26
Drives: Raven FR-S 6MT
Originally Posted by so26 View Post
Has anyone tried the 60-80mph timing feature in the torque pro app? I gave it a try the other day on a flat road and got 3.7s in 3rd gear, 5.0s in 4th, 6.6 in 5th and 8.0 in 6th. I'm curious what others are getting and what possible gains a tune will have on those numbers.
A little update so my previous times (see quote) were done with a Pennin LWP and drop-in filter installed; now I'm on a @FA20Club.com pump-gas tune as well. So I retested my 60-80mph times and got the following results. Note, I performed multiple runs in each gear and the times I'm showing is not necessarily the fastest time but the most consistent time.
Gear ..... RPM range ...... Time .... Difference from stock tune
3rd ...... 5357-7143 ..... 3.6s ....... -0.1s
4th ...... 4196-5594 ..... 4.7s ....... -0.3s
5th ...... 3468-4624 ..... 6.4s ....... -0.2s
6th ...... 2655-3540 ..... no noticeable improvement
I think they represent some good improvements ... to get better 6th gears times a header or FI would be needed to improve "the dip".
so26 is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
