Old 01-13-2013, 04:51 PM   #113
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
Did the fronts with 08+ Sti Brembos yesterday. Ended up stripping the bleeder plugs (one on each caliper) which was frustrating, but I just bled the brakes, unmounted, then mounted them. The look, performance, and feel I am all happy with at this point.
Thanks @King Tut for providing the mini write up and subsequent helpful posts. Also, thanks to @Racecomp Engineering for talking me out of buying the rear Brembos.
The Following User Says Thank You to BugeyedWagon For This Useful Post:
AZP Installs (01-13-2013)
Old 01-14-2013, 11:35 AM   #114
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
This is a concern perhaps, but due to the cylinder bores being the same, is it necessary? From what I understand, switching sides with the 4 pots is not a problem. Also, what of a pressure bleeder?
zohare is offline   Reply With Quote
Old 01-14-2013, 02:54 PM   #115
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
I found a set of 2004 sti brembos that Im gonna pick up tomorrow. I had purchased a set of Prodrive GC-07 in 17 x 7.5 + 48. What size spacer do you think i'll need to clear the new brembos?
Rims look like these ones
Thanks guys
fenixv8 is offline   Reply With Quote
Old 01-14-2013, 02:55 PM   #116
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Heat seems to be critical in getting those plugs out...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-14-2013, 03:00 PM   #117
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Why would you need heat to get the plugs out?
omegared19 is offline   Reply With Quote
Old 01-14-2013, 03:06 PM   #118
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Who were you replying to? The guy above you is using STI calipers, which are differential bored. The WRX 4 pots are not. The WRX 4 pots are actually less effective than our stock front calipers, minus the modulation/wear benefits.
Shifting the bias rearward may not be a bad thing if you don't disable EBD though, who knows.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-14-2013, 03:06 PM   #119
omegared19
omegared19's Avatar
Are you running the factory wheels? If not, what size/offset are you using? I'm dieing to get some new shoes on my ride!!
Old 01-14-2013, 03:07 PM   #120
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
After x years and xx,xxx miles they become corroded and stuck in the caliper. It's just an allex head plug so they strip out easily. Heat breaks that bond allowing their removal without damaging them.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-14-2013, 03:12 PM   #121
omegared19
omegared19's Avatar
Any recommendations on how to heat them up? I don't want to sit there like an idiot with my girlfriend's hair dryer for forever and not get them hot enough. I do have a heat gun, but don't want to strip the paint/STi logo.
Old 01-14-2013, 03:15 PM   #122
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A propane torch should work. The paint doesn't hold up to track temps so it'll likely brown a bit with the torch too. Ask Don @ Accelerated I know he heated the ones he test fit so he can tell you if it'll discolor the paint. You could maybe try an impact driver instead?
I'm using the Essex Sprint kit so I haven't had to deal with this issue myself
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-14-2013, 03:20 PM   #123
omegared19
omegared19's Avatar
Hmmmm......trying my best to not damage the coloring on the calipers. I like the black and want to keep them a bit incognito while I'm driving. Gonna do a bit of research into this.... I will post if I find a better solution.
Old 01-14-2013, 04:29 PM   #124
OrbitalEllipses
Drives: Attitude
The gold ones discolor to a brown, not sure about the black ones. You would definitely want a torch, a blow dryer is NOT going to cut it.
Old 01-14-2013, 05:46 PM   #125
BugeyedWagon
Suby Specialist
I heated mine. Was successful on 2 of 4 chances. I may have rushed it. I suggest patience.
Old 01-14-2013, 05:53 PM   #126
BugeyedWagon
Suby Specialist
No, stock wheels will not work.
Winter Set: Drag DR31 17x8 +? (I will check tonight)
Summer Set: Volk CT-C 18x7.5 +42
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
