Old 01-11-2013, 04:53 PM   #85
OrbitalEllipses
Drives: Attitude
He meant use the OEM BRZ or the OEM STI caliper mounting bolts. The bolts are different, so if you are doing this swap, make sure your calipers come with the STI caliper mounting bolts or here are the part numbers:
Front 901120103 ($3.67 x 4) M12 x 37 bolt
Rear 901000326 ($2.82 x 4) M10 X 38 bolt
I don't remember if I put anti-seize on mine or not, but I didn't have the torque specs at the time, so I used the German torque spec of guttentite with my standard 3/8" ratchet. I will probably apply some anti-seize to try and make sure they always come out when I need them to.
Bold portion correct. You can find those STI bolts at a local hardware store as well, in high tensile grade 10.x even! Guttentite's no good for these bolts my friend...remember when using anti-seize that you need to reduce your final tightening torque value as well! Don't forget to retorque/check torque on these bolts regularly.
Originally Posted by AZP Installs View Post
I'm not sure ghetto is the right wording. But yes, optimally, a matched front and rear setup is desired. Sometimes in racing you have to pick and choose your mods wisely.
I will caution, that unless one is doing this upgrade for a car with more power or some kind of sanctioned racing, or purely aesthetics, these brakes are a waste of time and money.
On the second half of that, use a ton of antisieze because 80% of the brembos we remove for rotor replacements end up having to be helicoiled.
Yes. Yes. Yes, but check what I said about final tightening torque above.
Originally Posted by Racecomp Engineering View Post
Adding the rear brembos actually puts more bias forwards. Sounds backwards, but it's due to the piston sizes compared to stock.
So the bias is actually better with just the front brembos.
- Andrew
Tiny piston area baby, tiny piston area!
SkAsphalt (05-03-2014)
Old 01-11-2013, 05:32 PM   #86
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
So besides the brackets from KNS that someone else mentioned...
Specifically what would one need to do this with 04-07 Brembos (as I'd assume they'd be cheaper and easier to fit 17s over)
Thanks
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-11-2013, 05:59 PM   #87
OrbitalEllipses
Drives: Attitude
Thanks
Talk to KNS to see if those brackets still exist.
It's been mentioned several times in this thread. You need: 04 STI front rotors OR 08+ STI front rotors REDRILLED to 5x100; 08+ STI rear rotors REDRILLED to 5x100; STI brake caliper bolts; BRZ brake lines; etc..
All the Brembo calipers are the same in size, just differ in mounting areas. There's no difference in what wheels fit 04-07 and 08+.
Old 01-11-2013, 06:12 PM   #88
seven
Tells it like it is
seven's Avatar
The site says they're on backorder
Yeah, forgot to mention the re-drilling, obviously, But I was aware of it - Ironically enough, it was the fact that it was mentioned so often that I, myself forgot to mention it, d'oh!.
I might make this a project sometime soon then. Thanks guys
*edit* actually... to be clear any reason you can't use 04 STI rear rotors? (since you only mention the fronts)
Old 01-11-2013, 06:36 PM   #89
OrbitalEllipses
Drives: Attitude
Rotor hat offset and backspacing is completely different. You can't use a 2004 STI "conversion rotor" either.
I suggest calling Ken...get a status update on those brackets if they even make them anymore. Good peoples. I've always ordered over the phone anyway.
Old 01-11-2013, 06:56 PM   #90
seven
Tells it like it is
seven's Avatar
Good info, thanks.
I'm not looking to upgrade the brakes this month but I might give him a call anyway (as if there's a wait it might speed things up )
Old 01-12-2013, 04:40 AM   #91
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Would I be correct in assuming no one has done this on stock wheels? I assume that's due to tires limiting our braking greatly... to me it looks like diameter they might barely clear the oe barrel but probably not width....
zohare is offline   Reply With Quote
Old 01-12-2013, 12:08 PM   #92
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
04 STi front rotors are already 5x100
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 01-12-2013, 12:10 PM   #93
AZP Installs
I'm pretty sure they won't clear the brembos. Not so much the tires but the rim design of the spokes. You would need to try it out and see.
-Mike Paisan
Old 01-12-2013, 12:10 PM   #94
AZP Installs
Good info, thanks.
Ken over at KNS Brakes is a great guy who has forgotten more about brakes than most of us will ever know about them!
-Mike Paisan
Old 01-12-2013, 02:22 PM   #95
OrbitalEllipses
Drives: Attitude
I've mentioned that numerous times. I said 04 STI rotors OR redrilled 08 STI rotors. :shrug:
Old 01-12-2013, 04:22 PM   #96
AZP Installs
Ah ha! Also 05-12 STi Rotors are the same.
They are actually pretty hard to find.
KNS sells the dual-drilled ones.
-Mike Paisan
Old 01-12-2013, 05:01 PM   #97
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Ah ha! Also 05-12 STi FRONT Rotors are the same.
-Mike Paisan
Fixed that for you. 04-07 STI rear rotors are different than the 08-12 STI rear rotors. Pretty much everyone sells the DBA dual-drilled rotors.
Old 01-12-2013, 05:05 PM   #98
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
So am I correct in saying that our hubs are 5x100 and the 08-12 STi hubs are 5x114, meaning that I'd have to buy new rotors anyways?
omegared19 is offline   Reply With Quote
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
