Old 12-30-2012, 10:03 PM   #71
OrbitalEllipses
Drives: Attitude
The STI logo is pained on so you would have to sand it off or repaint over it.
Wear proper gloves that wont melt, don't get any on your skin, wear a respirator.
Old 12-30-2012, 11:24 PM   #72
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
The STI logo is painted on so you would have to sand it off or repaint over
Ahhh, oh well, thanks for the info.
kmbkk is offline   Reply With Quote
Old 12-30-2012, 11:55 PM   #73
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by 2point0 View Post
I had 17s on my 2010 STi so I would think it'll work on the BRZ too. Just make sure your wheel spokes can clear Brembos.
04 STi wheels or any other wheels for the 04 STi should clear without a problem.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 12-30-2012, 11:58 PM   #74
AZP Installs
Originally Posted by Jamifra View Post
so basically in order to isntall the calipers you have to buy thicker/larger rotors?
i have a set of 04-07 sti brembo at home.. does the larger rotors apply to this brembos too?
Yes you need 04 compatible front rotors to fit the front brembos.
-Mike Paisan
Old 12-31-2012, 01:00 AM   #75
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
So would doing just the front completely screw up the brake bias?
fenixv8 is offline   Reply With Quote
Old 12-31-2012, 01:30 AM   #76
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
The cost of this setup is depressing. I did a full brembo swap on my sentra for around $800 with used parts.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Respect BRZ (02-14-2016)
Old 12-31-2012, 01:36 AM   #77
Jamifra
Jamifra's Avatar
Drives: 2013 Civic Si
Exclamation
that stuff burns!!
Driving Style: Highly Spiritual, Sometimes Aggressive, Never Abusive
Jamifra is offline   Reply With Quote
The Following User Says Thank You to Jamifra For This Useful Post:
TouchMyHonda (02-01-2014)
Old 12-31-2012, 01:23 PM   #78
AZP Installs
Haven't tested this on a BRZ, however we raced with larger brakes up front on our Subaru race cars (96 Impreza, 94 Legacy Turbo, 97 Impreza Swap) and we never had issues of brake bias that we couldn't correct with pad selections.
-Mike Paisan
The Following User Says Thank You to AZP Installs For This Useful Post:
fenixv8 (12-31-2012)
Old 01-09-2013, 02:02 PM   #79
hypermax
hypermax's Avatar
Drives: BRZ Limited
Hi, King Tut, I just got the 08 STI calipers, I would like to know more thing before I start the project. am I going to reuse the bolts from oem brakes calipers? What other things do I need to be concern beside the bleeder valves. Don't want to stuck on the project and occupying my friend's garage for few days on waiting parts and parts may have chance for back order. That happened to me once when I was doing my Z project at my own house. Really painful.
I am still waiting the brake lines and rotors and (front line and rear rotors are back order at this time), so I have a like of time to wait so I will get all of them at once and install them without any "STOPS". Please let me know what else is there that I need to be concern, thanks.
hypermax is offline   Reply With Quote
Old 01-11-2013, 02:09 PM   #80
OrbitalEllipses
Drives: Attitude
-Mike Paisan
That's the ghetto way of doing it...but exactly what I did on my WRX because front bias even with the stock sliders was ridiculous.
Yes you reuse the OEM bolts. The main concern with those calipers is that they are FULLY aluminum, including the threads in the mounting ears. MANY people have had to Heli-coil/Time-Sert those holes with steel inserts because the bolts either practically welded themselves to the calipers through galvanic corrosion OR they damaged the threads while removing the bolt. My personal set (still torn apart over a year later ) has Time-Sert steel inserts just because I wanted to prevent any possibility of downtime in the future due to a #&*^ed thread.
Old 01-11-2013, 03:12 PM   #81
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
He meant use the OEM BRZ or the OEM STI caliper mounting bolts. The bolts are different, so if you are doing this swap, make sure your calipers come with the STI caliper mounting bolts or here are the part numbers:
Front 901120103 ($3.67 x 4) M12 x 37 bolt
Rear 901000326 ($2.82 x 4) M10 X 38 bolt
I don't remember if I put anti-seize on mine or not, but I didn't have the torque specs at the time, so I used the German torque spec of guttentite with my standard 3/8" ratchet. I will probably apply some anti-seize to try and make sure they always come out when I need them to.
The Following User Says Thank You to King Tut For This Useful Post:
SkAsphalt (05-02-2014)
Old 01-11-2013, 03:42 PM   #82
AZP Installs
I'm not sure ghetto is the right wording. But yes, optimally, a matched front and rear setup is desired. Sometimes in racing you have to pick and choose your mods wisely.
I will caution, that unless one is doing this upgrade for a car with more power or some kind of sanctioned racing, or purely aesthetics, these brakes are a waste of time and money.
On the second half of that, use a ton of antisieze because 80% of the brembos we remove for rotor replacements end up having to be helicoiled.
-Mike Paisan
Old 01-11-2013, 04:33 PM   #83
Racecomp Engineering
Adding the rear brembos actually puts more bias forwards. Sounds backwards, but it's due to the piston sizes compared to stock.
So the bias is actually better with just the front brembos.
- Andrew
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
AZP Installs (01-12-2013), fenixv8 (01-11-2013), Guillaume (05-24-2013), Jive Turkey (02-04-2013), SkAsphalt (12-10-2013), zohare (01-12-2013)
Old 01-11-2013, 04:47 PM   #84
fenixv8
fenixv8's Avatar
- Andrew
^Thank you good sir.
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
