#57 | |
Drives: 2013 Civic Si
i have a question.. that are the specs on your wheels? i have volk te37sl 18x8.5 35 offset in the front. does the rims clear the brembo?
Driving Style: Highly Spiritual, Sometimes Aggressive, Never Abusive
#58 |
NASA SpecE30 Racer
I would think those would clear. I have 18x8 +42s.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#59 |
Hook 'em
Very nice job!
#60 |
Drives: Whiteout FR-S
Looks great! Matches the car perfectly.
#61 |
Drives: White 2013 BRZ Limited 6MT
Ok, Tut, love the work/look. I'm working on it as we speak. Did your used caliper set come with the original carriers/brackets to bolt up to the knuckle, or are you able to use the BRZ carriers?
#62 | |
Drives: Attitude
Hotlinked image: ![]() The brackets are integrated into the structure of the caliper. More hotlink: ![]() The circled portions are brackets that mount to the rear between the knuckle and caliper; they are harmonic dampeners that Subaru used in an attempt to make the calipers more livable. |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | omegared19 (12-17-2012) |
#63 |
Good to know. This is going to make things a lot easier.
Next question, are the brake lines the same or do I need to get a conversion kit? (ie: is the Brembo side of the braided line different than the factory BRZ side?) |
#64 |
Drives: Attitude
I used 04 STI brake lines on my WRX stock calipers....so YMMV. Don't know if the banjo is the same, but I'd venture it is. Buy aftermarket BRZ lines and see if they fit, if not...return or sell.
#65 |
NASA SpecE30 Racer
I used brake lines meant for the BRZ so that the lengths would be correct. I have never seen STI brake lines, so I didn't know if they would work. The banjo bolt and threads are the same for the Brembo calipers and OEM BRZ calipers, but the brake line won't line up like it is intended to on the calipers due to each caliper having different notches on the back of the caliper for the hard line to rest on.
- King Tut
#66 | |
Drives: '13 BRZ in WRB--let's mod!!!
The stock front calipers & caliper brackets are 11.6lbs--the STi caliper is 8.7. So, if you can find a rotor lighter than the stock 86 rotors 17lbs(Girodiscs are 16.5lbs), there'd be an overall weight-savings of abt 3.4lbs/corner. On the rears, the STi calipers are 5.9lbs, compared to 5.8lbs stock--so a push, there. But the rotors would net you just over 2lbs/corner. Total drop in rotational/unprung ~11lbs--not bad. Granted, it's definitely pricier, but if you can come across all the parts used & priced right... Just throwing it out there. |
#67 |
Drives: Attitude
^2PC rotors are $700/pair and that's really the only way to drop mass from those heavy rotors. Once at that price point I'd just consider an aftermarket BBK made for the car; though I have yet to see one I like that is also good DD material.
#68 |
Drives: Scion FRS (Asphalt)
Thanks for the write up this is the type of brake upgrade im looking to 4 piston front/2 rear. Is it possible to fleash out the steps more with pics and then pin it?
#69 |
First 86 Driver Baby!
Drives: FR-S, Flex
How hard woulod it be to get the STI logo off the calipers? I may go this route, but don't think the STI logo would look right on an FR-S.
#70 |
NASA SpecE30 Racer
The STI logo is painted on so you would have to sand it off or repaint over
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z Last edited by King Tut; 12-30-2012 at 10:45 PM. |
| Tags |
| brakes, caliper, sti, swap |
| STI front brakes on BRZ (confirm) | michael317 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 123 | 05-23-2016 01:41 PM |
| GTS Front Brakes + Rotors + Pads | GC GTS Aero Kit | Australia Classifieds | 2 | 11-16-2012 06:20 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 11:08 AM |
